Discuss Could this have been done better? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Could this piping have been done any better? It looks so unsightly.
Not the best. Were they gas safe ?? Nothing wrong with the compression elbow but doesn’t show much in the way of pipe skills
Hi, thanks for your comments. Some of you can't see photo clear enough so here is a closer look, please ignore the TV cable. I would like some constructive advice from a professional if possible so I know how to ask a gas engineer or builder to put it right. It was a Gas Safe engineer who installed the fire and I also check him on the register. I didn't quibble about the price or asked for it to be done as cheap as possible.
Personally, I'd expect something on show like that to have executed with more consideration for asthetics.
Did you tell him(?) it was okay at the time? If you did, then I feel you have a little responsibility too.
It’s one of them depends where the inlet to the fire is
Ptfe tape over the olives and clearly been put on some of compression fittings threads.
It hasn’t been installed by someone who knows about making joints.
Could it have been done better? Yes
It is unsafe/dangerous? Maybe. Other people have discussed this already.
Was the option of hiding the pipe discussed?
Did you discuss your problem with the engineer immediately during or after the installation?
Can you go to a restaurant, eat a meal, pay the bill and then complain? Yes but probably not the best idea.
My recommendation is to call the engineer and discuss in a calm and reasonable matter the problem. If you want a neater pipe then you may get luck and he will do it for free. If you want it hidden, then it will cost you more.
Thank you. They were GSR I checked on the register it's just the copper piping that spoils everything. I wanted to know if it could be hidden safely or what's the alternative. I just want to know what to ask for.
Box it in but use cups and screws
Wow lol.
That fire can't be fully back to the wall.
Being a fuel effect I would have personally got a gas safe registered engineer around yesterday. (must have the fire element check back of card)
In regards to the pipework, it could have been done better but the main concern would be products of combustion entering the room if that type of fire isn't flush with the chimney.
Don't plaster straight onto a chimney, the heat will cause it to crack overtime
Reply to Could this have been done better? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
