Discuss Combi conversion nightmare in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
can anyone help before I start ripping up floor boards
Converting to a combi but I can’t get the heating to circulate to the rads
New boiler in the same place as old so piped up to the flow and return dropping from the ceiling
I removed the cylinder and piped the flow from the boiler to the flow out to the rads
I capped the cylinder return and stuck an air vent on but it wont circulate
I linked the primary flow and return in the airing cupboard and it circulated back to the boiler
It’s as though the rads are not connected to the return
You sure the main return is linked to the rads return now?
Could of been gravity hot water before
I would link the cylinder ret to boiler ret
Was the old sys working ?
I have only got 3 pipes in the airing cupboard
Flow and return from the boiler
Flow to the rads
The house isn’t old enough to be gravity
It seems like the rad return isn’t teed into the primary return
the main return has to be connected to the rads return else it would of never been connected
What does the boiler do ?
Boiler works fine if I link the primary’s in the airing cupboard
The heat doesn’t go anywhere when I remove the link
from left to right
Cold
Hot
Primary flow
Primary return
Rads flow
thought the primary return wasnt in the airing cupboard?
Defiantly got a primary flow and return
When I link them it circulates around the boiler
And what was flow to the rad from the old 3 port
Those are my three pipes I’m left with once everything was removed
Ideal independant
Cheap landlord job that was supposed to be easy
The boiler works fine when I link the primary’s in the airing cupboard
Have you got the new flow going up the old flow?
A lot of people struggle with y and s plans so if they messed it up they may have put a non return valve in which if you have the flow and return the opposite way round won't work.
It might be a numb question so excuse me (haven't seen it) but there's no high point to air lock in the connection from primary flow to CH flow to rads is there?
I put a vent in the airing cupboard
The only thing I can think of is the tenants went round with a spanner and shut off all the rads
I left it like this in the airing cupboard
Then linked the primary flow and return on the stumps for vents and the heating circulates to to the airing cupboard and back to the boiler
The rads dont heat
Return not linked?
Reply to Combi conversion nightmare in the Plumbing Jobs | The Job-board area at PlumbersForums.net
