Discuss Pressure reduction valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OK I still have an issue with my cold water inlet to my hot water tank. There is a series of valves (see picture) and the meter is showing nearly 9 bars of pressure. I have turned of the water supply and ran hot and cold taps but this meter is not moving. I have tapped it and it does not seem to be stuck. The hot water is running normally . I do not understand what is happening or what these valves do.
OK so the problem occurred when I think a mixer tap valve failed and I had cold water of the mains flowing into the hot water side of the boiler.
So I will not attempt to fix this myself I am just curious as to what could have happened and what these valves do?
german writing on the top of the right hand grey knurl
Reply to Pressure reduction valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which I and other residents in the building share as we have shared supply to bathrooms and kitchens) Under kitchen sink stop valve turns off cold water in...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in kitchen only Stopcock in kitchen wall panel turns off cold water supply in kitchen only Red gate valve in airing cupboard next to bathroom turns off...
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the dripping stopped. Recently it began to drip again and I replaced the valve again. But, it still drips sometimes. I’m trying to replace the valve on the...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
