Discuss Lost this job as I was to expensive in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
Lost this job to an unregistered installer. I know who fitted it but you can imagine the stuff you cant see when the condense run on full view is that bad on the outside of the house
I lose a lot of jobs due to these people or being cheap and cheerful with Ā£150-200 labour charge.
No cement around the flue
Wrong condensation pipe
Just knocked through wall
Wrong install of flue
No collar around the flue
Left old flue at roof
Left bricks at the roof
The. You start thinking what has this cost and whatā€™s the install inside
Canā€™t agree more with you..
Could I report the above install too? It seems to me itā€™s not done right as well as makes my eye cry..
Would you call gas safe to let them check this
You need the home owner to call
You can report someone who is working illegally
Reply to Lost this job as I was to expensive in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
