Discuss flexible mono block tap connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I was just wondering if anyone could help us find a flexible mono block tap connector like the one shown in the picture. It has a female end which is 15mm and the length of it is 450mm. It has a 10mm wide solid pipe on the end which needs to be 100mm long. All our local plumbing suppliers don't know where we can get one from? We have found a 300mm length one but the solid end is only 40 mm long (from screwfix and B&Q) but not the longer length we require? Any help will be much appreciated. Many thanks
Do you call your female customers "mate"? :p
Why not?
Is not everyone to be treated the same these days?
To 'consider' anyone based upon their gender, height, weight, hair colour or any other 'difference' one can conceive is surely *** 'ist' in 2019. ;)
My favourite is 'bonkers-ist' because my manners dictate I have to hold a door open for whoever it is following me - then one is abused. :rolleyes:
Reply to flexible mono block tap connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just replaced the old bathroom basin mono mixer taps, 2 tap heads, standard compression valve type, to a modern mono mixer single lever type. For some reason the hot water running on the new single lever mono mixer tap is slow flowing compared to the old ones. The cold water running...
3K
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
Our house was built in 2007 and we are the second family to live here - moving in in 2017. The central heating has been working fine - although the gas boiler is perhaps nearing the end of its life. But the boiler is not our current issue. Last winter two of the radiators did not heat up and...
A
Hi, I am trying to fit a replacement tap to a mini-sink that's built in to the top of a toilet. The original tap isn't made any more by the manufacturers - the nearest equivalent is apparently this one: GoodHome Lazu 1 lever Mini Contemporary Basin Mono mixer Tap | DIY at B&Q -...
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector, but it hasn't done anything to fix the leak (and has cost us over £200). The plumber has told us that it can't be fixed due to the height of the old...
