Christopher Powell
- Messages
- 40
Hi all can someone help me out. How exactly do I check the resistance on the solenoids of the gas valve I can't get my multimeter anywhere near the connections
Thanks in advance
Thanks in advance
Discuss Greenstar 24i junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Test it at the pcb before you got it make.I'm gonna order a new valve now anyway. Will give it a go. If it's not I'll have a gas valve for sale if anyone wants it haha.
Changed valve problem solved. You were spot on, cracks on both solenoidsI’d connect up my u-gauge to the gas inlet, if the pressure doesn’t drop on ignition (when power applied to gas valve) then it’ll be the valve!
Sometimes you’ll see cracks on the solenoids, this can be a sign it’s given up! You’ll need a torch & flexi mirror...
Reply to Greenstar 24i junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
