Discuss Come across this today ? Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi
Thanks for taking time to reading this
I’ve not come across a cylinder like this before
Oil boiler ,indirect cylinder works find but what’s going on up top please
Also there’s a bathroom radiator on the hot water side which is fine I understand that
Hope you can shed some light thanks
Looks like a prv at the back coming in but I’ve never seen a expansion vessel on a older cylinder
Early unvented ?
All the best
Not the best pic Sorry
Hmm. I spoke to the BBA some while ago. A guy who was orig committee setting up UVCs in 1985. He told me that no copper cylinder was BBA approved as they were too weak.
Could this therefore be someone's attempt at creating one? Ive certainly seen that - a block of flats in Harrogate where all the cylinders were std Jewsons withsome cont attached. Henxh contact with BBA. Just a thought.
Reply to Come across this today ? Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, looking for some recommendations for a slimline indirect unvented cylinder to go with a new system boiler that we're having installed soon. Only need around 120/125 ltr for our usage and could possibly make do with 100. Been looking at a few different brands including the Megaflo which...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the cylinder has been heated I get what sounds like a vibration. It generally starts about 1s after I open the tap and lasts for about 1.5s. I've...
2K
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future, but likely the PV kind rather than the thermal kind, and won't be having heat pump in the future. So the cylinder would be connected to the boiler at...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions about this below. I had intended to reuse the cold water tank and the cylinder sitting underneath it but my plumber suggested I replace the cylinder as...
