Discuss Just Need Boiler Identification??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DjClubber
I know this is a Vaillant, does anyone know the actual Model for this please?
I have just done a Gas Safety Inspection on it. But no idea what Model to put down on the CP12 LOL... For the age, good CPA, Flame Picture etc before write it out, want to check correct Gas Rate etc. its burning at 8.9kw net. Just want to confirm against MI...
Didn’t you take the case off ?
Did you check underneath or ontop where the flue is ?
Yes 100% i checked on the top where the flue is. Just a vent nipple and vertical flue, aps also there and exp vessel. NO DB. Underneath just a massive whole no base.
According to the master that is a VC 142E or 182E system boiler.
He also said - "That red light indicates ignition PCB, low water, no gas" & "Look at the gauge... it's on ZERO" "Needs water, possible overheat has tripped..."
It is a loverly bit of kit built like a tank & looked after will outlast these modern ones.
Absolute DIAMOND... Thats exactly what it is. Just pulled up the MI PDF... Thanks...
I rectified all the errors and topped the system back up. Just done a Gas Safety on it, needed to know the Model. Its the VC 112 thermoCompact. TY... Appreciated...
Send us your gas safe reg no and I will sort it
Reply to Just Need Boiler Identification??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone I need to replace this bath/shower mixer but cannot find any identification marks on it . Does anyone recognise it please. I need to replace with something similar Many thanks Paul
Why is the radiator feed approx. 24degC just beyond/out of the Vaillant gas boiler (and also at the first radiator), when I've set the flow temp to 53degC? With boiler firing, the 53deg setting is always flashing on and off on the display - does this mean it never actually gets to 53? Thanks!
Hello, my Vaillant VRT 392 Thermostat just stopped working, it's completely dead, I read another thread suggesting changing batteries, but this model does not use batteries, it's wired to a Vaillant control center VR65 with eBUS, my boiler is Vaillant ecoTEC plus 624, anyone can help identify...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended significantly since the boiler was installed. There's now 21 radiators/towel rails. It's getting to temperature, but even after balancing, it's not heating...
