Discuss Brrrrrr, Oil Worcester Danesmoor 15/19 lockout light on. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Too much talk about fossil fuels in the pub last night.
Our Oil boiler Worcestor Danesmoor 15/19 went into lockout last night. Makes no noise, tried bleeding but as nothing running no go. I switched the power off and back on with no change. Just has power and lockout lights on and can hear the timer running.
Its Sods Law that our woodburner is out of action too.
Any tips welcome please
Sorry should have posted in Oil section.
Tried the reset button - Lockout light goes out, can hear a buzz for a while then a click, a little more buzzing and then lockout light on again, then buzz stops. (tried this with bleed open)
Gonna be a two jumper day I guess !!
I have had issues with condensation forming inside the underside of the tank and dropping into and mixing with the oil contaminating it, that caused all sorts of ignition problems you need a company who specialise in oil and can test your oil supply and any remedial work will need to be done . Kop
Thanks all for the pointers. A couple of Q's. Can I test the oil myself somehow to see if contaminated? Can I power the oil pump etc. up on the bench to see if jammed etc?
I think your best option is to employ the services of a recommended oil engineer.
Who will be able to diagnose and repair your boiler,
Hopefully in one visit. If you ask they will also test the fuel tank for water as well.
Reply to Brrrrrr, Oil Worcester Danesmoor 15/19 lockout light on. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Worcester Danesmoor 20/25, about 18 years old. B11 burner. We came home a few days ago to find our boiler in lockout, and not wanting to restart, instead simply doing a pitiful whine. We called an engineer out yesterday who, after a quick diagnosis, worked out that the capacitor had gone. We...
2K
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and wouldn't fire up when reset so I called out the local (but recently retired) engineer to see what he thought. He thought it was the pump so he serviced the...
2K
Boilers been running fine since its last service in March but it went to lockout so I removed the front panel and found that the water pressure was just about zero. I filled it up to 1bar and pressed the reset button and she fired up OK but I noticed that the water pressure was rising a lot more...
3K
Since moving to our property in Dec 2017, the Worcester Bosch Greenstar 18/25 Heatslave, has had a recurring lockout problem, which 3 OFTEC engineers have not been able to diagnose/ resolve. Typically at night when on manual,with no hot water running and with NO HOT WATER demanded of it. The...
8K
Hi all, please could anyone who's got tips from the trade help advise me. My house has gas central heating with a combi valliant boiler. It's currently set on "auto" with a timer schedule: 5:30am-7:30am : 24 degrees C 4:30pm-6pm: 24 degrees C 6:10pm-9:20pm: 18 degrees C The schedule is based...
2K
