Discuss help with wiring up new boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matty Birch
hi I have just replaced a potterton promax he and cant get my head around the wiring to replace it.
5 cables in as marked on the original boiler are SL E N and 2 PFs but where was it getting the 240 from? And also why is there just 2 pump feeds going into same connector and nothing returning?
Have rang a few sparkles and non are interested as it's not a combi ... urgent help needed.
The old boiler doesn't require permanent live
Only switch live
So old boiler switch live
Neutral
Earth
Pump live
Does the boiler require a perm live ?
Pump live goes in the left hand drawing live
Neutral and earth in right
so the old boiler didnt have a 240 live going into it? Not sure on the permanent live will have a look through the book now. so if I take the pump feeds to the left can I link the 240 to the Live and neutral on the pump side on the left?
correct only power when it was calling
why would you want to link live to pump boiler sorts the power out for the pump so no need to link anything
just put the pump feeds in there may only be a live and its getting its neutral and earth from the heating wiring centre
or if you dont need a per supply just put the switch live in the live terminal
More than welcome I’m guessing it didn’t require perm live ?
Reply to help with wiring up new boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to do it myself. I have a Grant Combi 26e boiler. I'm replacing the old thermostat with a new one. Although the boiler is a combi, I think the old...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was done on my rental flat (1st floor) which has a 10 year old Aviston E-combi EVO boiler. It failed based on rusting external flu components, which has...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't compatible with the new universal one, but the wiring was pretty close AFAICT (N, L, 1, 3 & 4 connected) .When I first powered it up but didn't have any TRVs...
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the boiler running again. The only reason it has not been used i so long is the the zone valve kept getting stuck (would have fixed this myself if i knew!)...
