Discuss Waste Outlet Too Low In Wall for Basin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've messed up. I ran a new waste for the basin to the soil stack. I've since installed plasterboard and and tiled over the wall. Now it has come to fit the sink, it seems I brought the waste out too low.
What's the best way to overcome this? Even with the adjustable bottle trap I can't get it low enough to align.
Any help greatly appreciated.
Two glued elbows
https://www.NoLinkingToThis/p/flopl...Vg-d3Ch0vpgDeEAQYAiABEgJ3m_D_BwE&gclsrc=aw.ds
It’s not on show you have plenty of room in that cupboard to make something up
I just thought the same. I was always under the impression it’s better to have that quite low then too high up. Very often you get called out for a sink blockage or whatever reason and you see that you have got difficulties to put a proper trap in unless you install a waste and ripping the whole lot out.
Unless the trap hits the board beneath it, extend the inlet pipe and lower the trap. If it does, can you lower, or remove, the board?
I would use solvent weld elbow/pipe/elbow to bring it up; then use a p-trap , which gives you much more flexibility of fit as you can articulate the two sections to suit.
Not really a problem here, try it when you’ve brought the new pipe in too high - doh!
Reply to Waste Outlet Too Low In Wall for Basin in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks I’ve been asked to first fix a basin that has the chrome waste exposed. My problem is that the basin isn’t on site to allow me to get an accurate height for the waste but I do have some dimensions. I will attach a pic if it helps. I’ve marked it out where the basin height is 870mm...
I’m fitting a small basin on a floating countertop (30x40cm) and will be chasing the internal clinker block wall to around 100mm wide to accept a 32mm waste and two 15mm copper pipes. There is no option to box the pipes in whatsoever due to space. I’m looking to fill the cavity with foam rather...
Hi all, Desperately in need of help. Getting very annoyed with myself Replaced the click plug in my bathroom for a new Basin Slotted one along with the Thomas Dudley Basin Waste kit All relatively straightforward to put together but why is it still dripping I'm using the preexisting metal...
My bathroom Basin was installed some years ago by a professional plumber. For whatever reason, the waste was fitted using silicone rather than plumber’s mate. The floor was originally tiled, but I replaced it with high quality vinyl, when fractures began to appear in the grout. As part of this...
Hi Everyone, I recently brought a replacement Pop Up Waste from Argent K316-DL & the spec states it suits both overflow & non-overflow basins. However it has no slotted waste opening. How could this be used with sinks with an overflow hole & still prevent sink overflow? Thanks Natalie Argent...
