Discuss Burst pipe in my flat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have currently had a burst pipe in my flat, I was going away for a long time and I was trying to turn off my main water supply for the flat. I have a unvented cylinder system.
First, I turned off the switch for the cylinder, then I turn the handle of the three shutoff valves (one is above the cylinder), but after a few hours I was told that one of the pipe bursted....
I just want to know why and what did I do wrong.....
Guess you didn't turn the mains off
This is the picture of the cupboard, the red lever i turned off
Left brass stop tap is your mains stop tap
You probably won't of been able to turn it any way very stiff need tools
prob wont turn the hot water off but it could of been a heating system leak without knowing hard to say
If your plumber is reputable he'll be able to talk to you what happened and how you can stop it happening again. Do aks him and do let us know what he says. Wc1
Reply to Burst pipe in my flat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover with a plastic sheet and then screet on top. I called out my gas boiler cover to make a permanent repair. The company they sent out have said it is...
Hi everyone, How do you know if there is a cross over with the pluming system in flat? All pipe work under sink, bathroom etc in the flat itself are legit but the rising main is in the attic, there is one rising main pipe (22mm) which has two pipes teed onto it that deliver water to three...
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat. My flat kitchen and bathroom was always on mains supply (no tank supply at all) and the rest of the 5 flats were mains supply to kitchen and water...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed supply and all 6 in the block have a shared rising main pipe (I think unless there is meant to be more than one). Kitchen: From the ground floor to...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
