Discuss Caleffi Inlet Control Valve Hissing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Forum,
There is a Caleffi Inlet Control Valve (1 piece) connected to the hot water cyclinder and the cold feed, that is periodically (every 5 mins) hissing air, out of the grey catridge, when the hot water is heating.
- I've search around for an explanation without luck.
I don't believe that is normal, what is the cause/fix?
- On the outflow pipe is a Tun Dish, that has at somepoint had water flow, not sure when this occured, but not recently to my knowledge.
I have taken a video of the hissing, but haven't worked out how to post it here.
You need to get a G3 engineer ASAP, you can’t fiddle with this it’s too dangerous so I’m not going to tell you what’s wrong with it.
Now you are scaring me...
By the sounds of it I don't want to be touching it, only had a damn plumber in recently, he didn't say anything...
Where do I find a G3 engineer and do I need to turn off the heating/hot water??
Hi Ben-Gee,
though you aren't telling me what is wrong, I can guess that it is likely linked to my previous posts...
1) I've had to recently replace the pump and the Heating Expansion Vessel.
2) I have today discovered that I have an Automatic Air Vent leaking water.
- The AAV is at the top of the pipework, that feeds the hot water from the boiler into the hot water cylinder.
- I look inside the AAV to see if it can be serviced, it can't, it is clean as a whistle, I ordered a replacement.
- Is air trapped due to the AAV being knackered?? With the Inlet control valve now releasing the trapped air as pressure builds...
- Since the pump was installed, I have been having trouble expelling air...
And finally a few weeks ago the hot water wasn't heating, the theromstat had been knocked and wasn't taking a tempreature reading... I took the thermostat off and put it back, it then started working again.
So, as you see a lot of events have occured recently with the heating system, it all started will the towel rail in the top shower room, making a hell of a banding noise randomly in the middle of the night.
I've just sent a video of the hissing to the Plumber who installed the pump for me, he said to me it doesn't appear to be too serious... He will call me when he is free to do so
The G3 qualified plumber, tells me over the phone that the inlet control valve needs to be replaced, though he doesn’t believe there is any danger.
He suspects that the valve may have possibly been damage by the water pressure being increased due to more buildings going up on the development.
Sound plausible ?
Reply to Caleffi Inlet Control Valve Hissing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot water to fit a new bit of pipework and found that water wouldn't stop running until the cold boosted water was also isolated. Given this, it would seem...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into the unit; a spring check valve was placed on the cold line (per the manual) after which there is an expansion tank (on the cold line) in a T junction...
Rogelio
R
