Discuss Banging Pipes After New Megaflo Cylinder Installed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently had a new Megaflo unvented cylinder installed and have noticed that when the washing machine is running there is a significant banging noise coming from the pipework by the cylinder. This noise was not present before the new cylinder was installed.
Could this be water hammer?
Any help or advice appreciated.
Yes water hammer are the pipes you can see clipped ?
Yes they are clipped, although looking at them again one of the clips is broken off following the new cylinder being installed. The pipework has been moved as the side that was not painted silver is now visible.
Is this easy to fix please?
When holding this pipe does the water noise stop ?
Might be hot so be careful
Strange , can you post a pic of the pipework?
By 'running' do you mean 'filling with water' or just washing/spinning? Does the banging start suddenly when the filling stops or or does it start happening while the filling is in progess.
I'm wondering whether what you are hearing is stick-slip noise as a cold pipe, initially warm due to conduction from the the Megaflo tank inlet, is cooled rapidly when cold water is being drawn by the washing machine.
The photos don't show quite enough to see whether this possibility is a plausible explanation in your case.
Reply to Banging Pipes After New Megaflo Cylinder Installed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
