Discuss Honeywell evohome connected in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Roy
Hi ive bought a Honeywell evohome connected ATP921R3100 and need advice on connecting.
My boiler is a Worcester Bosch 18i system boiler
A honeywell t6360b dial thermostat
A myson 2mep 2c programmer/timer
Its a 3 story 13 year old house
Myson timer programmer is in the kitchen with the fused power isolater.
Honeywell dial thermostat is also on the ground floor by the front door. Ive looked and there are 3 wires connected.
Ive not yet looked behind the programmer.
The boiler is on the next floor and lastly there is unvented 170L hot water cylinder on the top foor with a junction box there.
For now i will only have the Evohome but will be fitting thermostats for the radiator and do i need the hot water thermostat?
Many thanks in advance.
Roy
Posted a few pics of the programmer which looks the same as a few different makes.
The wiring behind it and the bottom pic is the rear of the programmer with a wiring diagram.
Pic of the thermostat and wiring.
The other pics are next to the unvented cylinder.
A Drayton zone valve actuator and a Honeywell motorised valve.
And lastly the junction box that all the wires go to thats in the same cupboard.
Cant see anything in the boiler cupboard.
Hope this helps understanding my system.
Reply to Honeywell evohome connected in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the system). Currently I have a Honeywell Home Single Zone Thermostat (Y87RF2024) and I am thinking to get the Honeywell Home Mobile Access Kit RFG100 to get...
L
hello I have a Worcester greenstar 18Ri with a Honeywell st6400c timer next to the boiler and a dial thermostat down stairs. it is a system boiler not a combi and has a separate hot water tank. I'm looking to find out if I can replace my Honeywell timer st6400c for a Honeywell sundial RF2 pack 3...
Deleted member 120897
hey all, Based in South England, UK. Hope this is the correct place to ask and that ive added all the required info/images. I had an old boiler that was setup with my evohome system, 12 zones in my house, with controls on each radiator - all worked well. Honeywell THR99C3112 Evotouch...
I need a little help if possible as I am trying to check that my current system is running efficiently but not really sure how to check, sorry if this is a long one and I have tried to contact a Honeywell connected specialist but they dont seem interested unless installing a new system and the...
2K
E
I recently moved into a new property which has a gas boiler and: (1) A hot water tank - this is controlled by a Hive timer programmer (all good); (2) Wet underfloor system on ground floor - this is controlled by Heatmiser thermostats (all good); and (3) Radiators on first floor and towel...
