Discuss Cannot get shower riser rail off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there.
I got this shower from b and q and the shower head holder is slipping. My plumber put it in so I don't know how it fits together and I can't get it off ( I don't want to force it). I am guessing that the top or bottom bracket will come off. I asked at b and q but they couldn't help. It is 3 years old.
Can anybody tell me how to get it off to tighten the shower head holder?
My guess would be use a thin edge knife or similar to pop off the light grey rectangle on the bottom bracket. That will probably reveal a screw
any allen keys on the small flat ends?
Reply to Cannot get shower riser rail off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
We've just purchased a grohe vitalio joy 260 not realising the shower riser rail is not adjustable and it is too long/tall for our shower it hits the ceiling. Grohe say you cannot cut the rail/pipe and must purchase a smaller one off them.. has anyone cut one shorter before and been ok?
I own a Aqualisa Q shower but the pinch grip holder has broken but how to do get the bottom part off (see attached) so I can feed the new replacement part on to the shower rail? Any help or advice would be most appreciated.
2K
I've just replaced an Ultra SASF2 – M thermostatic shower cartridge together with the spring mechanism and the temperature sensor. My problem is this: If I install the thermostatic cartridge together with the spring mechanism and the temp sensor (i.e. do the job properly), the shower runs warm...
Please can someone tell me the best way of removing a siliconed folding support rail that has been siliconed to a tiled bathroom wall at my mums. I can't get a hacksaw blade in between the wall and the plate and I can't get any thin windscreen cutter wire in as there is no gap. I don't really...
I have a dead 1990s Triton T70 shower and, for purposes of replacement, I'd like to know if it's mains or gravity fed. As it won't even switch on, I cannot get any water out of it so I can't just switch off water at mains and see if water still flows from the shower. I note that current Triton...
