Discuss Green Residue on Pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone,
I apologise if there was a thread regarding this topic. I am a first time renter and I have noticed weird residue on the pipes - could you please shed some light on the subject for me? Is it worrying? I have noticed that the pipes in that area we're wet a couple of month ago.
I will report it to the landlord but he and the agency are usually very dismissive of everything and I want an honest opinion from you.
Thank you for all your help.
Reply to Green Residue on Pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom, initially thought it was the toilet, but after smelling the bath tub plug hole it appears to be coming from here. I removed the P trap and very little...
Hello Everyone ;0 Iv just discovered this forum, looking through internet to find a solution to my small problem. So I just reopened, builders opening in my 1930 ex-council house. And surprisingly, did find some pipes inside. Two look like water - those have been cut, and those are like side...
Hi there I’m 10 weeks pregnant and found out we have some steel galvanised pipes with corrosion which was causing our tap water to run discoloured for a few seconds when not used for a couple of days. I understand this is from rust but was told lead could also be leaking into our water because...
Hello all, I realised yesterday that I now have a massive leak coming from the where the pipe below the sink goes into the wall. Every time water is used (sink, washing machine, dishwasher), it leaks from the junction of the pipe / wall. You can see on the pictures that there is some gross...
Deleted member 120897
Hi everyone, Recently all the water tanks in the attic were disconnected to connect to the mains water supply (mine was already on mains but the other 5 flats in the building needed to be connected to mains water) and the company were also going to fit PRV's and isolation valves to the pipework...
