Discuss low loss header, domestic system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Would you install a small low loss header on the following system.
62 sq m of underfloor(divided into 3 zones)
2 radiator zones(7 radiators each)
1 water cylinder
My boiler engineer suggested it, it makes sense to me(although its an extra cost!). A very good friend who works in the trade thinks not.
yes only reason i would is the under floor heating
you can use close tees if he wants
Reply to low loss header, domestic system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am looking to replace my existing Vaillant heat-only boiler with a new Vaillant ecotec plus 630 system boiler (30kW). I have a megaflo hot-water cylinder, a central heating system (serving 21 radiators) and an orangery built last year (6m x 4m) with underfloor heating. Through running some...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
I am starting a large victorian renovation and it will involve, (amongst everything else) installation of an entirely new heating and plumbing system. Plumbing, like most trades, seems to have two main aspects; design and installation. The installation part on my last two projects was painful...
Hi all Following some advice earlier this year on here, I finally have new boiler due to be fitted soon. I’ll be fitting a low loss header as advised due to loss in Vaillant 637. I currently have a Grundfos usp2 on my open vent system which I was planning on using for the time being until the...
