Discuss Worcester cdi classic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi all. Hope you had a good week.
I got the above boiler which keeps going to lock on only in hot water. Occasionally it lights when the heating is on and you turn it on. Got some new probes for it but anything else you think it could be.
Cheers
So looking this up it seems you can just use a pencil and this fixes it?
Not gas related but I am in need of some Mcalpine T29-LN's anyone know who stocks them as I cannot really wait for delivery.
Cheers
city should have them or bss
So It doesn't look like I will get those T29's by tomorrow. Can anyone recommend an alternative to connect to a 1 1/2 waste that does not need a trap.
It is for connecting to waterless urinals. Cheers
I'm sure they do an 1-1/4 & 1-1/2 hepvo
You can get bent or straight adapters.
In fact I have one on my bath tub
yea arnt the adapters 11/4 to 40mm tho? havent use one in ages so might be miss remembering
arnt the inlets only 11/4?
You would have thought so, but for some reason this perticular model is 1 1/2. I tracked down a supplier of the T29-LN and got them delivered special delivery. Also ordered some of the 1 1/4. All arrived today but no T29-LN. grrr.
I have so many jobs that are just not getting finished for some reason or another and it is literally making me want to go pop
Happens to us all mate. Keep your chin up
So here is the answer.
Black dust: pipework and gas valve full.
New carcass and good to go. Thanks all for help
Gas pressure must of been non existent?
It was actually fine the 1st time I was there but only there for quick due to it being an evening. Then when I went back I had it on for longer and it shot right down to 4mb!! Where does this stuff come from as I did some work on this a month ago and pressure was fine
In short it's the gas dust aka Hydrogen sulphide
It's recommend to fit a filter before the boiler if it's that bad / had problems before
Reply to Worcester cdi classic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Worcester Bosch Greenstar 30 CDi Classic System ErP, Underfloor heating and DHWSystem. I have non return valve in the secondary return before the pump (DAB 65/150-3) which constantly rattles when the pump is running. Its been tried in both the horizontal and vertical modes with no effect. The...
3K
Hi guys... Happy New year to you all.... Been out to a Worcester Greenstar Combi last week.... Problems with hot water not getting very hot.... Boiler is set to max on and I'm getting about 40 degree out of the tap.... Turned of the flow and return at the boiler to check diverter but this made...
We have two issues. I suspect that they are not actually problems – the heating work fine. Worcester Greenstar CDi. Installed in unheated garage. Protected by Honeywell pipestat and froststat. 1. The garage was cold (approx. 7° C). The room thermostat had demanded heating and the...
2K
Hi I am new to this forum and looking for some help with an annoying issue with my Worcester CDi boiler ( installed about 2010 ). It provides heating and hot water ( through a separate lagged water tank). Over a year ago it started going into a mode for a number of minutes before it then...
2K
Hi, i was wondering if somebody could give me some advice..... I was called out to a boiler breakdown the other day. Worcester 15Ri. When i arrived onsite the blue light was flashing i put it into reset, fan started, boiler ignited . Boiler reached temp very quickly and shut down on overheat. I...
