Discuss Worcester Greenstar 37 CDi Combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Harvest Fields
Subscribed
Just walked into this, first time I have been here. 4 bed semi, 1 bathroom, 1 ensuite, 1 WC. I do not want to touch the thing. Ohh and the cover plate for the heat ex is t secured and moves all over the place. Tried to upload a video but it will not let me do pics will have to do.
New boiler
Sparky still got glass ?
No glass in the electrodes just steel.
Never had one this bad. Other than a new boiler? What you thinking?
New sump and seal new electrodes and leads as earth lead really loose and pulls off with no effort. New sensor for heat ex as clip heat damaged. Not even tested it yet.
If they want a repair
Yea looks like it's been changed so it's had work on it in the last 2 years ish
Case damage or just badly looking ?
Don't forget about the case seal
I would price up a repair but also price for a new boiler with warranty
I’m going to repair the seal on the cover plate and test. Will definitely price both options. But want it tested first. Never done a sump before? 2 hours?
Yea I'd everything goes ok but I would pressure wash the hex if it hasn't been serviced before
Reply to Worcester Greenstar 37 CDi Combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone! My Worcester Greenstar 30CDi Combi boiler started making a rather loud juddering noise two nights ago. I bled all the radiators and releaaed air from the system. Repressurised the system afterwards with the water valve and the noise had stopped... until about the same the next day...
Deleted member 120897
I have a 16 year-old Worcester Bosch Greenstar 35 CDi combi boiler, which is recently suffering from intermittent issues with the hot water. I usually get the shout from a family member who’s in the shower and found there’s no hot water. If I’m near the boiler when this happens, I can see the...
3K
I'm considering changing our current Conventional/Regular Gas boiler, to a Combi. The main reason for doing this, is so that I can run a more effiecent shower. eg: With a better temparture control, combined with a better flow rate. But in order to get a combi with a good hotwater...
I live in a large 3 bed semi with a Potterton Profile 60e - so it's a G rated boiler. I wish to improve the energy efficiency of the property over the next few years, and part of that is obviously upgrading the central heating system. We have a tank in the bathroom which I want to move (to...
Hello - I was hoping for some advice and opinions on a new combi boiler I currently have a 3 bed semi with a myson orion boiler (it isnt a combi) - the boiler was installed around 1989, hasn't given any problems and is still working fine. Due to the increase in gas prices it is time to change...
2K
