Plumbing & Plumbers Forum - Teeing in mains to feed a tea cabin.
Discuss Teeing in mains to feed a tea cabin. at UK Plumbers Forums; Ive been asked to run a mains feed to feed a tea cabin in a courtyard behind a shop. Its on land being leased from the shop which has the ...
    Feb 2015
    47
    Default Teeing in mains to feed a tea cabin.
    Ive been asked to run a mains feed to feed a tea cabin in a courtyard behind a shop. Its on land being leased from the shop which has the mains water supply. They want me to tee into their supply underground and run the new pipe to the new tea cabin. It will involve digging a trench across a 3m wide right of way tarmac access road to a house, packed gravel and soil either side.
    The existing mains supply is about 450 deep. What would be the minimum allowable depth for my supply trench for this purpose. Im thinking the trench only needs to be wide enough to pick down to a suitable depth. If I dug a trench just wide enough to get the pipework down 200mm? Please help, im not sure where to begin.
    Mar 2013
    1,447
    Default Re: Teeing in mains to feed a tea cabin.
    750mm depth required, no matter what others have done. Establish position of other utilities and pipe runs. Tarmac, 3 metre wide, can in most cases be thrust bored to avoid disturbance and making good. Provided trench 3 metres long can be dug one side, thrust bore can be simple as scaffold tubes and 14lb hammer.
  3. The Following User Says Thank You to joni os For This Useful Post:
    newcastle phill's Avatar
    Jan 2014
    3,650
    As above 750mm. Youll be pleased when you dont a get call back for a burst pipe in freezing weather
    Using Tapatalk
  5. The Following User Says Thank You to newcastle phill For This Useful Post:
  6. #4
    Riley's Avatar
    Sarf Coast
    6,480
    And no deeper than 1350
  7. The Following User Says Thank You to Riley For This Useful Post:
  8. #5
    Feb 2015
    47
    Thinking about passing this one over to the water board. Thanks again.
  1. Teeing of 10mm feed(!) currently supplying plinth heater
    By DanF in forum Central Heating Forum
    Last Post: 01-09-2015, 06:56 PM
  2. Mains feed - moving/extending
    By mo7 in forum Plumbing Forum
    Last Post: 12-05-2014, 07:11 PM
  3. Mains feed to oil boilers?
    By plump in forum Oil and Solid Fuel Forum
    Last Post: 19-01-2013, 10:18 PM
  4. Shower cabin (free standing shower........ with just cold feed?!?!?!?!?
    By gregzapper in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-06-2012, 09:07 AM
  5. Mains feed pipe
    By bishbosh77 in forum Plumbing Forum
    Last Post: 11-05-2008, 10:11 PM
