Plumbing & Plumbers Forum - flexi hoses with rubber washers cause legionella to form
  • 1 Post By AlexGas
Discuss flexi hoses with rubber washers cause legionella to form at UK Plumbers Forums; have you guys heard of the flexi hoses are being removed from all council houses in scotland due to the material that the washer is made from and some of ...
    Jul 2013
    293
    Default flexi hoses with rubber washers cause legionella to form
    have you guys heard of the flexi hoses are being removed from all council houses in scotland due to the material that the washer is made from and some of the fibre washers too. it has been proved by scientists and tested by wras that the rubber washers and the fibre washers from a close up view. with a micro scope, has rough texture that legionella starts as a breeding ground. https://www.google.co.uk/url?sa=t&rc...8TGsDLISTXDZ5Q
    Jul 2013
    293
    Default Re: flexi hoses with rubber washers cause legionella to form
    THE LEGAL REQUIREMENT
    It is a legal requirement that flexible hoses are assessed by a competent laboratory for their compliance with BS6920: Parts 1 to 3. These tests assess the likelihood of the material being able to support microbiological growth and leach chemicals into the water with which they are in contact – chemicals which might either act as nutrients for bacteria, cause an adverse effect on the aesthetic qualities of the water (e.g. give it taste, odour, colour or turbidity) or be toxic to humans.
    Installers (plumbers) and Users (building managers) of water fittings are liable to prosecution for non- compliance with the Regulations. It is essential that unsuitable hoses are not used in wholesome water systems. Under the Regulations and Health and Safety legislation, the safeguard against prosecution for the use of unsuitable fittings leading to harmful effects on health is to insist on the use of fittings which have been assessed and shown to be satisfactory.
    9,632
    i call bull
    that means all boilers are done for then
    AlexGas's Avatar
    Sunny Southampton
    2,860
    Don’t think we can do much about tap washers now!?
    A few pints of beer – that’s all you need to keep safe!
    TFGplumbing likes this.
    Make it happen!
    Geyser's Avatar
    Jan 2014
    Somersetshire
    307
    I remember it being an issue in health care settings down here, there was a HTM on it somewhere. Ill try and find it. Think they just use regular documented flushing to overcome the problem. Its to do with the rubber lining on cheap flexible hoses, wras tested ones are ok.
    Geyser's Avatar
    Jan 2014
    Somersetshire
    307
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,664
    hospitals have had a purge on cheap flexis in the past due to the ability of bugs to breed in them, was good money for a couple of firms down here
    www.jcdheating.co.uk
  1. Flexi hoses
    By mo7 in forum Plumbing Forum
    Last Post: 29-11-2015, 07:16 PM
  2. Quantity of cistern conical rubber washers?
    By Guest123 in forum Plumbing Forum
    Last Post: 04-06-2012, 08:15 PM
  3. Replies: 10
    Last Post: 14-05-2012, 08:21 PM
rubber and legionella
