Results 1 to 12 of 16
Plumbing & Plumbers Forum - Would you agree this valve is suitable for use as a stopcock?
Like Tree15Likes
Discuss Would you agree this valve is suitable for use as a stopcock? at UK Plumbers Forums; Pegler Yorkshire - Pegler Yorkshire Tee Ball Valve 15mm Blue | Ball Valves | Screwfix.com G2.8 in the WRAS guide to the regs says 'spherical type valves may also be ...
    Jan 2015
    Powys, mid Wales
    217
    Default Would you agree this valve is suitable for use as a stopcock?
    Pegler Yorkshire -
    G2.8 in the WRAS guide to the regs says 'spherical type valves may also be used in all sizes'
    R2.8 in the WRAS guide to the regs says '[o]ther types of stopvalves and servicing valves may be used provided they conform to an appropriate British or European standard, or the Regulations, and are suitable for the purpose.'.
    This is full bore, rated at PN16, and WRAS approved.
    I think it's suitable. Would you agree?
    9,975
    Default Re: Would you agree this valve is suitable for use as a stopcock?
    No use a normal 15-22mm mains brass stop tap
    harrygashull and rocketmanbkk like this.
    Jan 2015
    Powys, mid Wales
    217
    Thanks. Your reasoning though?
    9,975
    Quote Originally Posted by Ric2013 View Post
    Stop tap has been used for decades with no problems other than normal wear and tear
    harrygashull likes this.
  5. The Following User Says Thank You to ShaunCorbs For This Useful Post:
    Masood's Avatar
    East London / Essex border
    4,822
    The same could be said of so many things but materials, design and manufacturing processes improve all the time.
    I see no reason for not using that valve although I prefer the lever type as they are a bit easier to operate.
    Find us at:
  7. The Following User Says Thank You to Masood For This Useful Post:
  8. #6
    Mar 2013
    1,442
    For the extra £1 go for one with a lever. The valve may not be operated for many years but when needed the reassurance of a lever will be worthwhile, especially for someone with weak grip or arthritis .
    Masood likes this.
  9. The Following User Says Thank You to joni os For This Useful Post:
  10. #7
    Neil K's Avatar
    May 2014
    Welwyn Garden City
    444
    I was taught in my apprenticeship not to use lever valves on cold water mains as they could/can cause water hammer
    Matchless.plumb likes this.
  11. The Following User Says Thank You to Neil K For This Useful Post:
  12. #8
    Masood's Avatar
    4,822
    Quote Originally Posted by Neil K View Post
    It's true they do about rapidly and can cause hammer but they're not in daily use so I don't think it's a big deal really. The reliability and ease of use more than makes up for it IMO.
    Find us at:
  13. The Following User Says Thank You to Masood For This Useful Post:
  14. #9
    Plumbers Arms member rocketmanbkk's Avatar
    Langley, Berkshire
    4,098
    Should it not be full bore to use as a stop tap? Any regs to say yea or nae?
  15. #10
    Member Matchless.plumb's Avatar
    Sep 2015
    782
    The reason I wouldn't install such a valve would be water hammer ... If you have a normal brass one you literally hit the water off in a soft and gentle way without ... It's just my opinion had to change few of them as a result of leakage , stuck, etc...
    But just my opinion
  16. #11
    Sep 2015
    782
    Sorry just related you didn't see you mentioned it
  17. #12
    May 2010
    3,451
    I thought the stop taps had that that anti back flow type washer or something... I would much prefer a nice lever valve on th incoming supply! We all get the stop Taps that are too tight or still pass water...
    We cannot help non gsr's with technical gas or boiler questions. If we do Croppie gets upset and gives us chinese burns......
  1. Stopcock/ valve leaking
    By Cristina in forum Plumbing Forum
    Last Post: 06-08-2015, 09:45 PM
  2. Dont agree to a job on a night out!
    By Niallmat in forum General Off-Topic Chat
    Last Post: 09-05-2013, 06:17 AM
  3. Lever valve as main indoor stopcock - Is this ok?
    By DarrenThomas in forum Plumbing Forum
    Last Post: 19-10-2012, 08:38 AM
  4. Shower valve suitable for the elderly
    By JonM in forum Bathrooms, Showers and Wetrooms
    Last Post: 07-10-2011, 07:15 PM
