Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Plumbing & Plumbers Forum - Would you agree this valve is suitable for use as a stopcock?
Like Tree15Likes
Discuss Would you agree this valve is suitable for use as a stopcock? at UK Plumbers Forums; They don't comply with the regs; no back flow prevention built in like a stopcock which has a loose jumper for said reason...
  1. #13
    NRS
    NRS is offline
    Oct 2015
    Reading
    Default Re: Would you agree this valve is suitable for use as a stopcock?
  2. #14
    Mar 2013
    1,442
    Would not want to rely on stop tap as backflow prevention device. Most loose jumpers, after years of remaining in open position become difficult to rotate and highly unlikely to remain loose enough to fulfil an anti-backflow function.
    Masood likes this.
  3. #15
    N.Ireland, United Kingdom
    6,986
    On this forum the same subject was posted and it was said that stopcock had to be fitted for regulations. Probably because it is anti back flow.
    Although I prefer lever valves for everything, stopcocks are better in one point, - they can't be knocked on accidently, unlike a lever valve. I wouldn't want to turn a lever valve off and rely on the customer or any children not knocking it on and flooding where I am working at. I do remove the lever temporary for safety though.
    Best solution is a stopcock on mains pipe with a lever valve directly above it for ease of use.
    Ric2013 likes this.
  4. The Following User Says Thank You to Best For This Useful Post:
  5. #16
    Jan 2015
    Powys, mid Wales
    217
    Just seen this thread has been resurrected.
    To answer two points:
    1. Water Regulations now prohibit a loose jumper in a stopcock. I know it used to be the opposite, and the C&G book of lies has yet to catch up.
    2. I'm not sure if full bore is specified, but I'd argue that if the valve weren't full bore it would not be suitable for use as a stopcock. My valve was full bore though - my feeling was that it would, therefore, be less restrictive than a BS1010 stopcock.
    I take the point about water hammer - and the accidental opening being easier!!
    rocketmanbkk likes this.
  1. Stopcock/ valve leaking
    By Cristina in forum Plumbing Forum
    Last Post: 06-08-2015, 09:45 PM
  2. Dont agree to a job on a night out!
    By Niallmat in forum General Off-Topic Chat
    Last Post: 09-05-2013, 06:17 AM
  3. Lever valve as main indoor stopcock - Is this ok?
    By DarrenThomas in forum Plumbing Forum
    Last Post: 19-10-2012, 08:38 AM
  4. Shower valve suitable for the elderly
    By JonM in forum Bathrooms, Showers and Wetrooms
    Last Post: 07-10-2011, 07:15 PM
