Results 1 to 8 of 8
Plumbing & Plumbers Forum - Any reason 1/2" Portsmouth (Part 1 ballcocks or FOV) are still sold at all?
Like Tree2Likes
  • 1 Post By JCSPLUMBING
  • 1 Post By Terry P
Discuss Any reason 1/2" Portsmouth (Part 1 ballcocks or FOV) are still sold at all? at UK Plumbers Forums; To cut a long story short, I started reading the the WRAS Water Regs book again: G16.1 d states that a G1/2 size valve (do they mean a 1/2" valve ...
    Jan 2015
    Powys, mid Wales
    204
    Default Any reason 1/2" Portsmouth (Part 1 ballcocks or FOV) are still sold at all?
    G16.1 d states that a G1/2 size valve (do they mean a 1/2" valve as opposed to, say, a 3/4" valve?) must be 'constructed so that the water shut-off level may be altered [...] without bending the float lever.' So why bother making Part 1 valves of that size at all?
    I suppose you could argue that replacing a valve does not constitute installing one so you can fit a non-compliant valve as a replacement? Is that why these are still sold?
    Just wondering as usual
    Thanks,
    Ric
    Apr 2015
    507
    Default Re: Any reason 1/2" Portsmouth (Part 1 ballcocks or FOV) are still sold at all?
    yep. They can be replaced but why on earth would anyone bother. Just use a part two.
    Ric2013 likes this.
  3. The Following User Says Thank You to JCSPLUMBING For This Useful Post:
    Jan 2015
    Powys, mid Wales
    204
    They were out of date in 1962, so I have no idea either. Still finding loads of them in service though.
    Apr 2015
    507
    I changed one yesterday funnily enough.
    Jun 2012
    London/Kent
    3,950
    Part 2's are only made in G1/2 & 3/4 sizes so if you want anything bigger it is still the Part 1.
    Also Part 2 is limited to the orifice size that can be fitted I seem to remember.
    Jan 2015
    Powys, mid Wales
    204
    That's my point: specifically, why bother making the half inch? What does the G stand for, by the way?
    R
    Jun 2012
    London/Kent
    3,950
  9. The Following User Says Thank You to chris watkins For This Useful Post:
  10. #8
    Aug 2016
    Many existing WC cisterns still in use have a Portsmouth float operated valve (part1), when the valve is in need of replacement the use of a part2 will not fit due to its air gap back flow protection of the water outlet at the top by means of the bent plastic water delivery spout sticks up too high for the cistern lid. The part 1 can be installed providing back flow protection is installed in the supply pipe in line with The Water Supply (Water Fittings) Regulations 1999.
    chris watkins likes this.
  11. The Following User Says Thank You to Terry P For This Useful Post:
  1. Posted question on sparks foum "part p"
    By wetdrip in forum Central Heating Forum
    Last Post: 15-08-2014, 05:38 PM
  2. """Pls help no hot water baxi 105e"""
    By f1fanman in forum Plumbing Forum
    Last Post: 20-02-2010, 01:32 AM
  3. Ballcocks again
    By malbro in forum Plumbing Forum
    Last Post: 18-02-2010, 09:04 AM
