Results 1 to 4 of 4
Plumbing & Plumbers Forum - double check valve requirements for incoming mains.
Discuss double check valve requirements for incoming mains. at UK Plumbers Forums; Hi all, current job to replace old lead incoming mains for 25mm poly pipe, from the meter in front garden to kitchen at back of house, 3 bed semi with ...
    Oct 2015
    Essex
    14
    Default double check valve requirements for incoming mains.
    Hi all,
    current job to replace old lead incoming mains for 25mm poly pipe, from the meter in front garden to kitchen at back of house, 3 bed semi with a combi boiler,
    !question! do I need to include a double check valve on the incoming mains water valve arrangement.
    many thanks
    dancinplumba's Avatar
    Beautiful Barlick
    7,115
    Default Re: double check valve requirements for incoming mains.
    your meter will act as a non return valve, but you will require a small expansion vessel (150ml) to take up thermal expansion
    >>>>>>>>>> I'M DANCIN, YOU ASKIN ? <<<<<<<<<<
    GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply
    Jun 2012
    London/Kent
    3,950
    No Tom you don't need one,
    With all due respect if you are going to start messing around with water / water mains you really do need to do the Water Reg's course, then you be able to self cert & know what is & isn't required.
    Oct 2015
    Essex
    14
    Yes true, it's a one off job I don't normally touch domestic, but didn't want to install incorrectly, think I'll pass this one off to a local plumber then.
    Thanks guys
  1. Identifying a double check valve
    By Helen Wilkinson in forum Plumbing Forum
    Last Post: 02-02-2012, 05:45 PM
  2. double check valve
    By pipeline in forum Plumbing Forum
    Last Post: 06-01-2012, 11:34 PM
  3. Can a double check valve become blocked???
    By Gilbo1 in forum Plumbing Forum
    Last Post: 15-12-2011, 08:44 PM
  4. Double check valve on shower
    By innertemple in forum Bathrooms, Showers and Wetrooms
    Last Post: 30-05-2011, 12:24 AM
  5. double check valve
    By plumdum in forum Plumbing Forum
    Last Post: 21-02-2010, 06:27 PM
