Plumbing & Plumbers Forum - Mono basin tap requires check valves or not?
  • 1 Post By townfanjon
Discuss Mono basin tap requires check valves or not? at UK Plumbers Forums; Open vented hot water and mains pressure cold water. When mixed temperature Could the cold water override the hot causing a poor temperature of the hot. can someone put me ...
    Jul 2013
    294
    Default Mono basin tap requires check valves or not?
    Open vented hot water and mains pressure cold water. When mixed temperature Could the cold water override the hot causing a poor temperature of the hot. can someone put me right. Thank you.
    Dec 2013
    The center of the universe
    4,268
    Default Re: Mono basin tap requires check valves or not?
    It depends on the tap tbh, but yes you should always fit a nrv on the hot , or i do lol
    ShaunCorbs likes this.
    10,197
    Quote Originally Posted by townfanjon View Post
    +1 or half the time they come with a decent tap combo(iso and scv)
  1. Check / Non Return Valve For Mono Mixer Basin Tap
    By DazJWood in forum Plumbing Forum
    Last Post: 15-08-2016, 12:05 PM
  2. Loose spout on mono basin tap
    By payvpac in forum Plumbing Forum
    Last Post: 12-05-2012, 02:16 PM
  3. Flexi Pipes Or Copper Tails For Mono Basin Tap
    Last Post: 25-02-2012, 07:18 PM
  4. Tall Mono Basin Tap On Travertine Surface
    By DazJWood in forum Valves & Taps
    Last Post: 09-02-2012, 03:39 PM
  5. Mono Basin Mixer Tap Problem Question
    By Stealth in forum Plumbing Forum
    Last Post: 11-08-2010, 03:58 PM
