Page 1 of 3 123 LastLast
Results 1 to 12 of 34
Plumbing & Plumbers Forum - WRAS question
Like Tree11Likes
WRAS question
Discuss WRAS question at UK Plumbers Forums; Hi I'm having a bit of a nightmare with quoting for a job. Customer keeps arguing the toss over a product that they want installing. They would like a douche ...
    Riley's Avatar
    Sarf Coast
    6,373
    Default WRAS question
    Hi
    They would like a douche installed in close proximity to the toilet ie there is a chance that the hose could end up in the pan. The product that they have purchased recommends an anti syphon valve to prevent backflow contamination. I was not sure about this and asked the question on here the other day and was kindly recommended to contact WRAS accordingly.
    I did this and received a very concise response re installing a separate water cistern with the necessary air gaps to ensure that contamination could not occur.
    I totally understand what I was sent and I have done my best to explain this to the customer however they cannot understand why it cannot be just installed as per the MIs. I can see both sides of the problem here but I am not keen to install in line with the MIs as this is a landlord property and don't want the Landlord to have any comeback or any subsequent WRAS follow up.
    Would i I be better off just binning this job?
    9,632
    Default Re: WRAS question
    cant you use a double check valve ?????
    Robert Tyrrell likes this.
    May 2014
    2,390
    If its a rented property why not just surgest to the landlord to just not install the douche
    Geyser's Avatar
    Jan 2014
    Somersetshire
    307
    No you can't. I had same problem after getting well into the job wben customer turned up with one.
    Rckape's Avatar
    Jan 2015
    Nottingham
    367
    A double check valve is only suitable for category 3 fluids. This install required protection from category 5 fluids, realistically a break tank is the only option.
    I'm sure if you look in the MI's it will have a clause requiring compliance with local regulations. As far as I know water MI's do not super cede water regs unlike gas.
    For me it's a case of doing it to regs or not at all.
    Of course it's much easier not to install in the first place.
    Masood and chris watkins like this.
    9,632
    Quote Originally Posted by Geyser View Post
    just had a quick look on the internet and most say fit like this
    http://www.wet-water.co.uk/images/st...connection.pdf
    and from wras them selves
    9. Bidets
    Generic specification is limited to over rim supply (not ascending spray) bidets only:
    BS EN 35 and BS 5505-3 – Pedestal bidets.
    BS EN 36 and BS 5505-3 – Wall hung bidets.
    See also BS EN 14528 Bidets. Functional requirements and test methods.
    Water supply to bidets is by separate taps or mixer tap (preferably thermostatic), with or without adjustable spray nozzles (described as ‘over rim’ supply). There may also be a diverter to supply a douche spray rising from the bottom of the bowl.
    Water Regulations or Byelaws usually have onerous requirements for the connection of bidets with rising douche or flexible handspray, e.g. a separate break tank. These measures will reduce water pressure, which may be inadequate for the bidet douche spray. Check the details with the manufacturer and/ or the water company.
    Riley's Avatar
    Sarf Coast
    6,373
    I did suggest that to lady at WRAS but she said it was insufficient for Cat 5 water
    Riley's Avatar
    Sarf Coast
    6,373
    Quote Originally Posted by Rckape View Post
    My thoughts exactly
    Riley's Avatar
    Sarf Coast
    6,373
    Quote Originally Posted by plumben View Post
    Tenants want it for "religious" purposes
    1,990
    Problem solved, No risk here then;
    https://www.youtube.com/watch?v=qU4TxkougK8
    May 2014
    2,390
    Quote Originally Posted by Riley View Post
    That doesn't justify installing one, and the extra expenses for the landlord, the next tenant will want it removing, they can stand in the bath/shower tray and use the shower if they need one that bad
    Riley's Avatar
    Sarf Coast
    6,373
    Oh I know and don't get me wrong I totally agree. The landlord is happy as they're good tenants and are willing to contribute to the cost
  1. What is subject to WRAS approval?
    By Rodolphe in forum Water Regulations
    Last Post: 29-11-2012, 07:36 PM
  2. WRAS distance elarning course
    By DAVE1982 in forum Plumbing Forum
    Last Post: 30-10-2012, 08:48 PM
  3. WRAS website link
    By Guest123 in forum Plumbing Forum
    Last Post: 15-07-2012, 10:22 AM
  4. WRAS vs Building reg G3.
    By jackplumb in forum Plumbing Forum
    Last Post: 25-06-2012, 10:27 AM
  5. WRAS Certificate
    By toonjabba in forum Plumbing Forum
    Last Post: 16-04-2009, 10:09 PM
douche water pipe install price plumber
