Plumbing & Plumbers Forum - MDPE in concrete
Like Tree2Likes
  • 2 Post By lame plumber
MDPE in concrete
Discuss MDPE in concrete at UK Plumbers Forums; Hi, I've extended my mains water mdpe pipe through into my new extension and brought it up through the slab under the new kitchen window. However, I've had to change ...
    Default MDPE in concrete
    I've extended my mains water mdpe pipe through into my new extension and brought it up through the slab under the new kitchen window. However, I've had to change my kitchen window into a set of French doors and so the pipe is now in the way. I want to break into the slab back down to the dpm that is on top of my rigid insulation and redirect the pipe to where the sink will now be located (approx 500mm away). Is it possible that if i do this can I just pour concrete over the pipe and connectors? Or does it all need protecting? It's a 4" slab so I haven't got room to lay the pipework in any ducting or use pipe lagging etc. I just want to make sure that the concrete won't damage the pipe or connectors. Any advice would be greatly appreciated.
    Thanks for your help.
    Jim
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,670
    Default Re: MDPE in concrete
    dont use a connector under concrete, just a complete length of pipe, best its laid in conduit to a protect it and b allow for changing it in the future if things go wrong
    Riley and Masood like this.
    www.jcdheating.co.uk
  3. The Following User Says Thank You to lame plumber For This Useful Post:
    Jan 2015
    92
    2nd the above.
    You would just be storing up probs for later if you buried the connector in concrete.
    10,219
    as above do not and i mean Do Not put connection where you can not have access to them, or if you do be prepared to rip every ting out when it leaks
    stevetheplumber's Avatar
    east london
    10,613
    in an ideal worldthere shouldnt be connectors in the concrete but do you mean concrete or screed ive buried lots of fittings in screed without problems and as tamz said some times you need to pish with what you have
  1. MDPE laying
    By supper plumb in forum Plumbing Forum
    Last Post: 07-07-2013, 09:47 PM
  2. Mdpe to CWSC
    By on31ll in forum Plumbing Forum
    Last Post: 31-03-2013, 04:19 PM
  3. MDPE Above Ground
    By Veggie Dave in forum Water Regulations
    Last Post: 18-07-2012, 03:41 PM
mdpe pipe buried in concrete
mdpe pipe connection in concrete
why cant i concrete mdpe
mdpe fittings in concrete
mpde pipe fitting concrete
