Chatrooms
Water main advice needed -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Water Regulations
Notices
Old 17-01-2010   #1 (permalink)
arhplumbheat
Info
Default Water main advice needed
Hello all, I have been tasked with installing a new kitchen sink into a farmyard barn. The nearest mains water is suppying toilet about 45m away inside another barn which is conected to the barn i need to install the sink in.
My question is can I run a mains supply from the existing toilet room to the sink unit surface mounted? It will be inside another building so is it classed in the same way a 'raising main' is within a house situation or not?
Many thanks
arhplumbheat is offline
Old 18-01-2010   #2 (permalink)
WHPES
Info
Default Re: Water main advice needed
Anything which is connected to a rising main is treated the same under the Water Regs regardless of application. As long as your pipework meets the requirements you will be OK.
You may consider using MDPE pipe due to the application and pipe run.
WHPES is offline
Advice require - Electric Water Heater / Old Gas Boiler salbal77 Plumbing Forum 2 16-04-2009 08:16 AM
Hwlo with wold water tank overflowing philwilliams Plumbing Forum 2 13-04-2009 08:57 PM
gravity HW & mains CW mixer tap problem MarkB Valves & Taps 7 23-03-2009 12:51 PM
Advice needed! - new water supply pipe pressure trevarooney Plumbing Forum 1 08-09-2008 12:34 PM
