Plumbing & Plumbers Forum - outhouse utility room conversion
Discuss outhouse utility room conversion at UK Plumbers Forums; im converting an out house into a utility room. their is already a drain for sewage as theres a working toilet in there. we want a washer in there. plumbing ...
    Sep 2010
    Default outhouse utility room conversion
    im converting an out house into a utility room. their is already a drain for sewage as theres a working toilet in there. we want a washer in there. plumbing in the washer is easy really. going too draw off the water form the toilet supply pipe as theres good pressure and flow so the tricky bit is how do i convert the old cast iron soil pipe from the wc so i can drain off from the washer into it? someone did suggest that i can just drain the washer water outside on to gravel but i figured this sounds somewhat dodgy as the waste water would be full of chemical from soaps and detergents. any advise would be good cheers. also i do think this outhouse used to be a utility room or someone has tried as along with light theres recently tested electrics in there eg sockets and trips etc.
    Norfolk
    3,000
    Default Re: outhouse utility room conversion
    Cast iron soil pipe boss
  3. The Following User Says Thank You to Reg Man For This Useful Post:
    509
    I don't personally like connecting to cast so I would replace all of part of the stack with plastic and use a boss or a stap on boss onto plastic
  1. Warmflow utility 90 he combi
    By P J F PLUMBING in forum Oil and Solid Fuel Forum
    Last Post: 19-08-2013, 09:07 PM
  2. Replies: 6
    Last Post: 01-08-2013, 01:04 AM
  3. Greenstar Utility 32/50
    By Millsy 82 in forum Oil and Solid Fuel Forum
    Last Post: 22-12-2012, 12:32 PM
  4. National utility solutions
    By roguetrader in forum New Member Introductions
    Last Post: 11-08-2012, 04:18 PM
  5. Nat Utility Solutions
    By andyatkins2477 in forum Plumbing Forum
    Last Post: 24-07-2012, 03:22 PM
  6. soiled utility
    By Mahesh in forum Plumbing Forum
    Last Post: 31-03-2012, 07:35 AM
  7. Warmflow U70 Utility Room Boiler Problem
    By steve5345 in forum Plumbing Forum
    Last Post: 31-01-2012, 12:36 AM
  8. Worcester Camray utility 25/30
    By Chrisgy in forum For Sale & Wanted
    Last Post: 21-11-2011, 09:08 PM
  9. Moving utility room soil pipe
    By Kriggi in forum Plumbing Forum
    Last Post: 17-08-2011, 05:07 PM
converting outhouse to utility
convert outhouse utility room
convert outhouse to bathroom
converting outhouse into shower room
outhouse wc into utility room
