Results 1 to 6 of 6
Plumbing & Plumbers Forum - Pipe lagging
Pipe lagging
Discuss Pipe lagging in the Water Regulations at Plumbers Forums; Ok, Dumb question time, I always lag my pipes wherever I have to with climaflex, however my local DIY shop has ARMAFLEX, this is black and is not slit so ...
    Robtheplumb
    Default Pipe lagging
    Ok, Dumb question time, I always lag my pipes wherever I have to with climaflex, however my local DIY shop has ARMAFLEX, this is black and is not slit so you would have to slide it onto the pipe before making any joints, the good thing about this is it can not fall off (or be pulled off).
    What is the differance between climaflex and this armaflex???
    Feb 2009
    340
    Default Re: Pipe lagging
    i think as its a different material works a bit better but normally you cut it on the use there solvent to put back together
    Robtheplumb
    What I tend to do for the uncut stuff is to slip it on first, this is a bit of a pain but it does mean that Mrs woman can't pull it off as soon as I leave to make her airing cupboard warmer
    Plumbing Forum Contributor
    Apr 2009
    68
    Armaflex works well on runs underfloors if using 10mm pipe on rads.
    Feb 2009
    Liverpool
    1,972
    Check the heat loss per metre to find out if one insulates better than the other.
    Robtheplumb
    Quote Originally Posted by Bernie2 View Post
    Good plan... in fact to oviouse for me to think of
  1. Shower Pump & Pipe Diameter Question
    By spcdust in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-08-2009, 01:13 PM
  2. pipe lagging
    By feltham in forum Plumbing Forum
    Last Post: 25-04-2009, 04:34 PM
  3. Pipe CHASING electric shower
    By bureaucrazy in forum Bathrooms, Showers and Wetrooms
    Last Post: 08-04-2009, 10:06 PM
  4. Relocating Soil Pipe Venting
    By DazJWood in forum Plumbing Forum
    Last Post: 26-02-2009, 08:20 PM
  5. pipe lagging
    By katieheaney in forum Plumbing Forum
    Last Post: 20-02-2009, 08:01 AM
climaflex vs armaflex
whats the difference between armaflex and climaflex
pipe lagging regulations
whats the differnce beetween armaflex and climaflex
armaflex lagging
armaflex laging
