Results 1 to 15 of 15
Plumbing & Plumbers Forum - water regulations and self-certification
Discuss water regulations and self-certification in the Water Regulations at Plumbers Forums; Hi all, I'm a student plumber on an NVQ2 plumbing/heating course. At some point, I'll do the BPEC water regs certificate. But in the meantime, I'd be grateful for advice ...-
04-02-2012 #1New to Plumbing Forum
- Sep 2011
- 23
Hi all,
But in the meantime, I'd be grateful for advice about self-certification and water regulations? Which jobs need to be certified them? And who could certify them if you don't have a certificate?
Jennie
04-02-2012 #2Plumbers Arms member
- Dec 2011
- 134
- Thanked 17 Times in 17 Posts
Re: water regulations and self-certification
here is a list of job which need a certificate which can be issued by an approved plumber The installation of a water fitting in connection with:
1. The erection of a building or other structure, not being a
pond or swimming pool
2. The extension or alteration of a water system on any
premises other than a house (#)
3. A material change of use of any premises
4. The installation of:
a. a bath having a capacity, as measured to the centre
line of the overflow, of more than 230 litres (*)
b. a bidet with an ascending spray or flexible hose (#)
c. a shower unit of a type specified by the Regulator
(none are currently specified) (*)
d. a pump or booster drawing more than 12 litres per
minute, connected directly or indirectly to a supply
pipe
e. a unit which incorporates reverse osmosis.
f. a water treatment unit which produces a wastewater
discharge or which requires the use of water for
regeneration or cleaning
g. a reduced pressure zone (RPZ) valve assembly or
other mechanical device for protection against a
fluid which is in Fluid Category 4 or 5
h. a garden watering system unless designed to be
operated by hand (*)
i. any water system laid outside a building either less
than 750mm or more than 1350mm below ground
level.
5. The construction of a pond or swimming pool over
10,000 litres capacity, designed to be replenished
automatically with water supplied by a public water
supplier. (*)
06-02-2012 #3New to Plumbing Forum
- Sep 2011
- 23
Thanks so much for that. I'm quite relieved - I can at least do some small jobs until I get that certificate. Thanks.
06-02-2012 #4New to Plumbing Forum
- Oct 2008
- 17
- Thanked 5 Times in 5 Posts
Need to be careful with the list quoted as most of these items require a compliance certificate to be issued on completion but also required notification to the water company for consent to be granted before the work takes place.
There is very little in this list that you can actually self certify without water company involvement. See wras website for more detail.
Jon
26-07-2012 #5New to Plumbing Forum
- Jul 2012
- 3
How long are these certification course? How many years course are these?
26-07-2012 #6UK Plumbersforums Trusted Advisor.
- Hastings
- 3,901
- 45
1 day but need minimum NVQ level 2 to enrol.
26-07-2012 #7Plumbers Arms member
- Jun 2012
- London/Kent
- 1,723
- 102
- Thanked 183 Times in 179 Posts
06-08-2012 #8New to Plumbing Forum
- Jul 2012
- 3
OK.. Thanx for the information. Means one need to work and study very hard.
17-08-2012 #9New to Plumbing Forum
- Jul 2012
- 3
Does these certification exams have pre-entrance test too?
17-08-2012 #10UK Plumbersforums Trusted Advisor.
- May 2008
- Bolton
- 4,183
- 190
- Thanked 352 Times in 332 Posts
No. But as stated you should be nvq trained already
Sent from my GT-I9100 using Tapatalk 2IN CERVESA FELICITAS - IN BEER THERE IS JOY
I am responsible for what i say, i am not responsible for how much of it you actually understand
Brevior saltare cum deformibus mulieribus est vita
27-08-2012 #11Plumbers Arms member
- Jun 2012
- London/Kent
- 1,723
- 102
Just for the record, the BPEC water reg's does not as I understand it require prier attainment of an NVQ (it might well be a distinct advantage), all that is required is you work within the industry & have prior knowledge of plumbing systems. This is needed to allow building / facilities managers & the like, to acquire knowledge & competency to check & monitor their buildings. I am sure there are other examples as well but this was one that came to mind.
10-12-2012 #12UK Plumbersforums Trusted Advisor.
- Nov 2010
- Norfolk
- 1,270
- 90
- Thanked 146 Times in 134 Posts
Great list by Aqualogic7. Also unvented hot water systems?
10-01-2013 #13New to Plumbing Forum
- Jan 2013
- 8
Sorry ! Unvented will require another course
courses courses courses ???
10-01-2013 #14Super Plumbing Forum Contributor
- Jan 2011
- York & Leeds
- 1,569
- 31
- Thanked 139 Times in 136 Posts
19-01-2013 #15Steady Plumbing Forum Contributor
- Oct 2009
- Swindon
- 117
- Thanked 1 Time in 1 Post
But then you need to register with an approved installer scheme recognised by the water authority that cover the area you are working in.
I just joined APHC as we have just renovated 6 flats and 2 shops in a listed building. Waterboard still came out and signed it all off but it's worth having.
Water Regulations Training
By ProffesorPlumb in forum Water RegulationsReplies: 30Last Post: 2 Weeks Ago, 08:11 PM -
Water softener regulations
By Paul Cockhill in forum Water RegulationsReplies: 9Last Post: 3 Weeks Ago, 08:54 AM -
G3 Water Regulations
By rideorhide in forum Plumbing ForumReplies: 3Last Post: 07-11-2011, 01:44 PM -
IMI range Tribune 2 unvented cylinder/ Cut off water and water regulations
By Paul Cockhill in forum Plumbing ForumReplies: 2Last Post: 07-11-2010, 07:16 AM -
Water regulations traning.
By plumermicky in forum Plumbing ForumReplies: 1Last Post: 07-06-2009, 02:07 PM
1Likes
price guides
1 Hour Ago in Plumbing Forum
