Plumbing Forum Plumbing Forum Plumbing Forum Plumbing Forum Plumbing Forum
Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK Plumbing Forum Sponsorship Armadillo Workwear for Plumbers Drill Tough Objects Plumbing Forum Sponsorship
Plumbing Forum | Plumbers Forums | A forum for plumbers in the UK » Plumbing Forums » Water Regulations
Water Regulations Discuss all aspects of the Water Regulations in this forum.
Old 11-02-2008   #1 (permalink)
Unregistered
Posts: n/a
Default Isolating Valves
Do isolating valves prevent water backflow.
Old 14-02-2008   #2 (permalink)
ajs heating
Default Re: Isolating Valves
no a check valve does that
__________________
ajs heating is offline   Reply With Quote
Old 17-02-2008   #3 (permalink)
ProffesorPlumb
There are different backflow prevention devices for different scenarios.
Water Regulations are very strict on where these are installed. It is a legal offence to not use the correct backflow prevention on a system if its needed.
Old 19-02-2008   #4 (permalink)
SteveO
NO. A single or double check valve will do this as per the water regs.
SteveO is offline   Reply With Quote
Old 07-03-2008   #5 (permalink)
sibs
In what circumstances would you need either a single or double check valve to prevent backflow?
sibs is offline   Reply With Quote
Old 1 Week Ago   #6 (permalink)
chawkey@hotmail
depends on what fluid category you are dealing with, outside taps you should use a double check valve as a hose pipe could be connected to it and so increase the risk of backsiphonage. There are all also RPZ's which are used for zone protection mainly in comercial premmesis, but for domestic best to use a double check valve if in doubt
chawkey@hotmail is offline   Reply With Quote
You may post new threads
You may post replies
vB code is On
Resolved Question: Where can I get radiator bleed valves? - Old Style ones.? RSS Feeder Plumbing Questions 0 08-01-2008 04:21 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
