Plumbing & Plumbers Forum - Water fountain drain - Storm or foul?
Discuss Water fountain drain - Storm or foul? in the Water Regulations at Plumbers Forums; Does a drain from a water fountain have to go into a foul drain or can it go to a storm drain? It's a fountain with a bubbler/carafe filler and ...-
20-04-2011 #1New to Plumbing Forum
- Apr 2011
Does a drain from a water fountain have to go into a foul drain or can it go to a storm drain? It's a fountain with a bubbler/carafe filler and was going into a storm drain but we've been told it shouldn't.
Thanks in advance for you assistance.
20-04-2011 #2UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
Re: Water fountain drain - Storm or foul?
i cant see why it cant go in rainwater unlikley any ones going to add any chemicals or soap our shool playground ones used to go straight on the floor
21-04-2011 #3UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Correct me if I am wrong but I seem to think the regulations state that no foul water must enter the surface water drain rather than detailing specific appliances, so as long as you can achieve this you are OK. The only issue I can see is the chlorination of the tap water but don't know if this is relevant or not.
26-04-2011 #4Steady Plumbing Forum Contributor
- Sep 2010
- The 'Tropical' South
- 184
- 7
- Thanked 21 Times in 21 Posts
foul drain i think, it's technically potentially contaminated so i'd have thought it should not go into the rainwater drain.
28-04-2011 #5UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
Can go into surface water if there's no chance of contamination.
drinking water fountain question
By turnpin in forum Plumbing ForumReplies: 10Last Post: 14-04-2011, 08:54 PM -
Faulty drinking fountain tap
By Connor Williams in forum Plumbing ForumReplies: 3Last Post: 28-02-2011, 02:18 PM -
foul smell
By BREIAN in forum Plumbing ForumReplies: 5Last Post: 14-09-2010, 10:26 AM -
Foul Smells
By copperman111 in forum Plumbing ForumReplies: 0Last Post: 02-06-2010, 10:41 AM -
MX Atmos Storm Mixer Valve
By Daniel in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 30-03-2010, 11:17 PM
Eco funding
5 Minutes Ago in Central Heating Forum
