Plumbing & Plumbers Forum - ACL Drayton A679B316-52L0 diverter valve
Discuss ACL Drayton A679B316-52L0 diverter valve at UK Plumbers Forums; I have an old heatslave boiler and the diverter valve gears have worn away. I want to replace it before I replace my boiler in the summer. Been told by ...
    Jan 2017
    Default ACL Drayton A679B316-52L0 diverter valve
    I have an old heatslave boiler and the diverter valve gears have worn away. I want to replace it before I replace my boiler in the summer. Been told by local merchant that my model, A679B316-52L0 is dicountinued. I looked at another Drayton diverter valve and the connections are male not female.
    Has anyone replaced just the gears on the valves and are they available? The motor gear side is fine.
    Any help will will be appreciated.
    Jan 2017
    Default Re: ACL Drayton A679B316-52L0 diverter valve
    I replaced the diverter valve today with a Drayton 679-3, I could only get the MA1 mid position actuator. Can this be wired up to use as a ZA3? If so can you give the details. There is no brown cable.
    tamz's Avatar
    Scotland
    13,977
    It would have been easier to buy the correct diverter valve
    Use both the white and grey as the live
    Make safe the orange wire as it will power up
    Blue is neutral and green yellow is your earth
    When power is applied the valve will open port A. When not powered it will spring return to port B
  1. Faulty Drayton MA1 Mid Position Valve
    By Jim H in forum Central Heating Forum
    Last Post: 27-10-2015, 06:58 PM
  2. Faulty Drayton Mid Position Valve?
    By HughCallaway in forum Central Heating Forum
    Last Post: 07-02-2015, 12:15 AM
  3. replacing diverter valve without removing diverter housing?
    By wesley in forum Central Heating Forum
    Last Post: 09-01-2015, 12:34 PM
  4. Drayton/ACL lifestyle mid position valve
    By TBServices in forum Central Heating Forum
    Last Post: 11-12-2013, 03:15 PM
  5. Leak between DHW Flow Valve and Diverter Valve Assembly
    By prestonperson in forum Plumbing Forum
    Last Post: 01-04-2011, 01:25 PM
