Results 1 to 6 of 6
Plumbing & Plumbers Forum - Tap dribbles after being turned off.
Discuss Tap dribbles after being turned off. at UK Plumbers Forums; Hi again. I have just bought a new mixer tap and I have an issue turning it off. Every time I turn it off, I either get a dribble of ...
    Aug 2015
    11
    Default Tap dribbles after being turned off.
    Hi again. I have just bought a new mixer tap and I have an issue turning it off. Every time I turn it off, I either get a dribble of water until the tap tube is empty, or it stops as it should but then any knock or movement of the tap then means that remaining water in the tap dribbles out.
    It looks to me like when the water gets turned off, the water stays in the tap tube and forms an airtight seal of water at the very end exit point of the tap. Then any knock shifts it and allows air in, braking the seal/vacuum and spills the water out.
    Is there any any solution to this? A couple of friends have said they have heard of this before but don't know the answer. It's very annoying.
    This is the tap https://houseofenki-imdtradingltd.ne...-milan_3_1.jpg
    steve.
    N.Ireland, United Kingdom
    6,991
    Default Re: Tap dribbles after being turned off.
    That design of a spout will probably always dribble. The top of spout is a long horizontal run and water will exit that when the vertical drop is disturbed.
    Only thing that would help really well would be an airator on end of spout, but that design of rectangular spout would probably not have possibility of one.
    You could try contacting manufacturer
    Aug 2015
    11
    Thanks Forbes your suggestion. I did contact him previously and he just pretty much said it isn't a fault with it so get on with it. Lol. I will try and find an airater as it does splash a bit too. Thanks.
    6,991
    Airator helps the left over water to hold in the spout. That tap is special though.
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,667
    daft designs always dribble
    www.jcdheating.co.uk
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    3,669
    you can get rectangular aerators but they are not too common so sizes and availability are quite restrictive
    Regards
    Tom
  1. When is a turned off tap not turned off?
    By Jgo in forum Plumbing Forum
    Last Post: 30-08-2016, 11:48 AM
  2. Cant Identify Kitchen Mixer / Hot Tap dribbles
    By suremane in forum Valves & Taps
    Last Post: 25-04-2014, 06:37 PM
  3. shower hot when tap turned on
    By Theladyplumber in forum Plumbing Forum
    Last Post: 28-09-2012, 05:04 PM
  4. Toilet that sometimes dribbles!
    By dearl in forum Sanitary Ware
    Last Post: 18-05-2009, 11:20 PM
tap dribbles after turning off
tap always dribble
