Results 1 to 12 of 12
Plumbing & Plumbers Forum - blowing in the wind AKA can anybody identify this?
  • 1 Post By snowhead
Discuss blowing in the wind AKA can anybody identify this? at UK Plumbers Forums; Hello I know this is a long shot but there's no harm in asking. The most trival of faults is going to cost me dear. I simply can find nobody ...
    Dec 2016
    Default blowing in the wind AKA can anybody identify this?
    Hello
    The most trival of faults is going to cost me dear. I simply can find nobody who can identify this mixer or the cartridge in question.
    The blue compression washer has fatigued slightly, causing a drip when the unit is off. Although I have stopped the drip by using a bit of Vasoline, I don't know if that will last if I run the water (can anyone give a view of that?)
    I have searched high and low to replace the cartridge but to no avail. There is no branding on the unit or the cartridge. Showerdoctor didn't even reply when I pleaded for help
    I've attached some pictures in the vain hope that someone recognises it. The unit has two outputs one for the shower and one for the bath. The middle control is a Thermostatic control.
    If anyone can save me having to replace the WHOLE unit (including all the tiling damage etc) I'd be eternally grateful.
    (Note the bigger blue washer is one I bought hoping it would be the right size. The one on the right (with Vasoline on it) is the actual washer.
    Regards, Paul
    blowing in the wind AKA can anybody identify this?-img_20160903_121721.jpgblowing in the wind AKA can anybody identify this?-img_20160903_121742.jpgblowing in the wind AKA can anybody identify this?-img_20161213_191304.jpgblowing in the wind AKA can anybody identify this?-img_20161213_191251.jpg
    N.Ireland, United Kingdom
    6,991
    Default Re: P*****g in the wind AKA can anybody identify this?
    How about just trying to add a thin washer to it, or replace the original washer from spare parts? Measure the washer diameter. Pity a standard inexpensive ceramic gland wouldn't have same size.
    It takes very little to compress the ceramic works better. I have used rubber O ring on some ceramic 1/2" taps to make a repair when nothing else was available.
    And welcome to the forum.
  3. The Following User Says Thank You to Best For This Useful Post:
    2,030
    Best likes this.
  5. The Following User Says Thank You to snowhead For This Useful Post:
  6. #4
    Dec 2016
    Hi! See the larger blue gasket in my picture? That's where I got it from, believe it or not! It was far too big as you can see. Which was annoying in the extreme, because I thought I'd nailed it!!!!
  7. #5
    Dec 2016
    Hello, that had crossed my mind too. Worth a try perhaps!
  8. #6
    9,993
    Default Re: blowing in the wind AKA can anybody identify this?
    sharp razor blade and cut the new one down in height wants about 1mm bigger/ higher than old one
  9. The Following User Says Thank You to ShaunCorbs For This Useful Post:
  10. #7
    Dec 2016
    The bummer was that not only was the height an issue, it was a tiny bit thicker than the original so didn't want to sit in situ. I'm guessing that is down to the metal reinforcing ring in the gasket.
  11. #8
    9,993
    Quote Originally Posted by pewatts View Post
    the metal ring should come out and is it bigger on the diameter ?
  12. The Following User Says Thank You to ShaunCorbs For This Useful Post:
  13. #9
    Dec 2016
    So it does! Although it is taller but I wonder if I can shave a bit off with a Stanley Knife?
  14. #10
    Dec 2016
    Click image for larger version.
    And yes, subtly bigger on the diameter. Subtly. Perhaps talking the ring out is enough? I'll have to wait and see; the wife has embargoed me playing now in case I wake the Rugrats!
  15. #11
    9,993
    depends how much bigger on dia if not much worth a try and yes a sharp knife blade on the height remember to add a mm think it will be on where the metal ring sits ish
  16. The Following User Says Thank You to ShaunCorbs For This Useful Post:
  17. #12
    Dec 2016
    Yep agreed. I'll give it a go and report back. Thanks all for your ideas and assistance, I appreciate it.
  1. wind turbines take a hit
    By Puddle in forum General Off-Topic Chat
    Last Post: 09-12-2011, 07:01 PM
