Results 1 to 9 of 9
Plumbing & Plumbers Forum - Boiler not firing
Like Tree6Likes
  • 2 Post By APPlumbing
  • 2 Post By SimonG
  • 1 Post By rpm
  • 1 Post By Swale
Boiler not firing
Discuss Boiler not firing at UK Plumbers Forums; Hi all i would really like some advice please 2 zone heating 1 upstairs 1 downstairs on an ideal combi boiler 2 Honeywell cm707 programmable stats one for each valve ...
    Nov 2016
    Default Boiler not firing
    Hi all
    wired to Honeywell junction box(wiring centre) as follows
    perm live from fused spur to term 1
    perm live from term 1 to boiler
    perm live to both stats in term 1
    perm live (grey) to both valves in term 1
    All neutrals in term 2
    all earths in term 3
    the stats have the perm live going in term A with the
    return term B out of stat (black) going to wiring centre in with brown upto valves
    orange from valve back to wiring centre with a grey going to boiler s/l
    each black from stat go into a separate terminal 4 and 6 with a brown from the valve
    when the stat is pumped up for heat the valves open but boiler does not fire is the wiring correct
    the valves are Drayton any help much appreciated thanks
    rpm
    rpm is offline
    Member rpm's Avatar
    Wherever I lay my hat
    7,840
    Default Re: Boiler not firing
    Mr Swale of Swale Heating, currently taking a bashing on another forum?
    Responsible Moderator...
    APPlumbing's Avatar
    Locks Heath fareham
    13,386
    Quote Originally Posted by rpm View Post
    You're such a forum tart!!!
    I nearly joined swale about 18 years ago....
    Swale and Masood like this.
    I have an unfortunate problem. I should stand upwind if I were you!
    SimonG's Avatar
    16,038
    Use a tester to check power at necessary points. Simple s plan.
    rpm
    rpm is offline
    Member rpm's Avatar
    7,840
    Quote Originally Posted by APPlumbing View Post
    APPlumbing likes this.
    Nov 2016
    Hi Iam not mr swale Iam a new build installed trying to get my head round this 2 zone heating that contractors want in, never done it before, swale is the river next to me
    rpm likes this.
    Nov 2016
    Thanks for reply, 240v at both terminals 4-6
    240v at terminal 10 orange x 2 and s/l grey upto boiler
    240v at boiler perm live and switched live when stats are on
    Masood's Avatar
    East London / Essex border
    4,769
    Quote Originally Posted by Swale View Post
    Hi all
    Sorry, I'm finding it hard to visualise what you're describing. A photo or diagram would be really helpful.
    Alternatively, take a look at the Honeywell website for a standard S-plan system which is what you're trying to configure. Follow the diagram and you won't go wrong. Terminal numbers and wire colours aren't that important, just follow the switching sequence..
    Find us at:
    Mar 2013
    1,340
    Use multimeter not volt stick. If perm live and s/l going to boiler are both 240v. then, other than checking fuse on PCB, you will need GS engineer.
  1. oil boiler not firing
    By Inverness in forum Oil and Solid Fuel Forum
    Last Post: 06-01-2016, 11:07 PM
  2. Boiler not firing up, or only firing up briefly.
    By Unregistered in forum Central Heating Forum
    Last Post: 04-01-2016, 01:12 AM
  3. Boiler not firing
    By milkman in forum Central Heating Forum
    Last Post: 09-03-2009, 11:38 AM
  4. Grant Oil Boiler Firing, stopping firing etc?
    By jimk280 in forum Central Heating Forum
    Last Post: 08-12-2008, 11:21 AM
