Results 1 to 8 of 8
Plumbing & Plumbers Forum - Rising Main Brass Stop Taps
  • 1 Post By Zagga
Discuss Rising Main Brass Stop Taps at UK Plumbers Forums; Just about to have a new 25mm mains supply buried to the road and need a brass stop tap to connect to the MDPE pipe and wondered if there were ...
    Sep 2016
    Default Rising Main Brass Stop Taps
    Just about to have a new 25mm mains supply buried to the road and need a brass stop tap to connect to the MDPE pipe and wondered if there were any recommendations for a good quality tap that hopefully won't restrict any flow.
    It has to be a 25mm MDPE to 22mm copper and looking at some taps it looks like regardless of the outlet size, the bodies are the same so a 25mm x 15mm tap will have the same body as a 25mm x 22mm thus restricting flow down to a 15mm bore.
    Thanks for any tips.
    10,020
    Default Re: Rising Main Brass Stop Taps
    You will be fine with any decent valve pegler is a good brand
    Sep 2016
    Thanks!!
    Just looked at the Pegler website and it seems the 25mm MDPE to 22mm copper is under the Kuterlite range and costs a eye watering £109
    Is that what a good stop tap costs or are these designed for off shore oil rigs??
    10,020
    Quote Originally Posted by Zagga View Post
    Thanks!!
    Is that from plumb centre as there always 3 - 4 times the piece
    https://www.ondemandsupplies.co.uk/p...-Stopcock.html
    Or go to a local plumbing suppliers
    But tbh go with the best one you can locally there all near enough the same
    Sep 2016
    Ha yes, it was the plumb centre.
    Thanks for the link, the 25mm MDPE stop taps on the site you linked are less than £10 so why on earth are the Kuterlite ones so MUCH more expensive (cheapest I've seen is still £65)?
    10,020
    It's a brand / name same as off brand vs Samsung etc
    Mar 2011
    554
    how about using a 25x3/4" FI adapter, then a 3/4 brass hex nipple, then a 3/4 screwed lever valve, wont get any less restrictive on that....actually if you got a MI (male iron) adapter you wouldn't need the nipple.
    I've never used a lever valve as a main stop tap, but I believe you can do so now.
    Sep 2016
    Thanks for all the help.
    I originally thought lever valve but when the guy for the water board came to inspect our proposed plan I asked about this and his response was we'd need an stopcock at first entry into the house and then we could fit a lever valve as a fail safe but tap needed to be first.
    Anyway, I've just decided to bite the bullet and get the Kuterlite K777 after reading horror stories about cheap stop taps leaking or even popping off. I managed to get it for £50 which may be overkill for a domestic job but at least its got 25 years guarantee, WRARS approved and a good flow rate.
    ShaunCorbs likes this.
  1. rising main
    By Rodders111 in forum Plumbing Forum
    Last Post: 12-05-2016, 07:12 PM
  2. Lead rising water main
    By Steve Macca in forum Fittings & Pipes
    Last Post: 06-12-2013, 11:44 PM
  3. 50mm brass stop tap
    By midlands based in forum For Sale & Wanted
    Last Post: 03-11-2013, 08:47 PM
  4. Seized Rising Main - Any ideas?
    By jlbreak in forum Valves & Taps
    Last Post: 09-09-2010, 10:54 PM
  5. Lead rising main
    By Jock Spanners in forum Plumbing Forum
    Last Post: 31-01-2010, 12:51 PM
rising main tap uk
