Results 1 to 12 of 12
Plumbing & Plumbers Forum - Imperial stop cock
Imperial stop cock
Discuss Imperial stop cock at UK Plumbers Forums; Can a current standard stop cock be fitted to an imperial body sweated between lead & copper pipe?...
    Sep 2016
    Default Imperial stop cock
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,121
    Default Re: Imperial stop cock
    When you say that do you mean replacing the innerds of the tap ?
    If you do mean that, I would say no.
    I may be wrong of course.
    Why can't you just replace the whole tap or have I misunderstood?
    Sep 2016
    Thanks for the response. Can't replace the body without cutting old (sweated) body out from lead pipe and jointing lead incomer which has been cast into concrete floor (1960's extension). Pipe is not smooth and only short stub available without excavating concrete (& probably damaged). If I could replace the valve section (innerds) it should solve the problem
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,859
    is there space above the old stop cock to cut another one in?
    Sep 2016
    Hi Steveb. This is not the problem, there is already a second (working) stop cock above the floor. The problem is a slight leak which has gone unnoticed from the old cock below floor level and caused significant damp. Just need to cure weep at tap body/valve seal.
    9,661
    Quote Originally Posted by andyjohnson15 View Post
    Where's it leaking from andy ? The spindle or the join from the body to the base ?
    Sep 2016
    Looks like just from the body to the base. Tightened packing gland and that seems fine.
    Aug 2016
    Lancashire
    1,121
    loctite 55
    you'll need to turn water off outside unless you're brave !
    Sep 2016
    Cheers LP. Tried Fernox LS-X but no joy. I'll give 55 a go
    Aug 2016
    Lancashire
    1,121
    you need to wrap around the back of the thread to sandwich it between the body and flat part of innerds, (name escapes me). there used to be a fibre washer in there which has possibly broken, hence the leak.
    don't put it on the thread though. The joint is where those two flat surfaces meet.
    you may be best with water off and removing innerds to clean that surface off properly first.
    Sep 2016
    My thoughts too. Cheers LP
    9,661
    Or use loctite 577 on the threads of the body but as above water will need to be off
  1. Replies: 4
    Last Post: 11-01-2016, 05:45 PM
  2. Imperial stop tap
    By Alfie in forum Valves & Taps
    Last Post: 28-06-2013, 04:09 PM
  3. solenoid stop cock
    By handsomejackuk in forum Valves & Taps
    Last Post: 14-12-2012, 09:54 PM
  4. Stop cock key
    By herbert in forum Plumbing Forum
    Last Post: 24-11-2012, 05:38 PM
  5. Outside Stop Cock(Tap?)
    By smellynose in forum Valves & Taps
    Last Post: 04-09-2009, 02:19 PM
