Results 1 to 12 of 18
Plumbing & Plumbers Forum - Heating System Isolation valves
Like Tree5Likes
Discuss Heating System Isolation valves at UK Plumbers Forums; Hi Forum, What valves can i use to isolate a section of my heating system 22mm in size. Do they make a pushfit version? cheers Chris...
    Sep 2016
    Default Heating System Isolation valves
    Hi Forum,
    cheers
    Chris
    Last Plumber's Avatar
    Aug 2016
    Lancashire
    1,426
    Default Re: Heating System Isolation valves
    Gate valves.
    Not sure on push fit because I don't use them.
    Jan 2014
    447
    gate valves ...right...so i can fit a couple of gate valves on the flow and return above my open vented boiler,close and run,no probs,few clues in above,glad you are gas safe and hopefully signed up for gas awareness week...
    ShaunCorbs likes this.
    9,993
    where are the valves going/ being installed op?
    thereisawizza's Avatar
    May 2010
    Hythe, Kent
    588
    Gate valves? Bit last century :-)
    rpm
    rpm is online now
    Member rpm's Avatar
    Wherever I lay my hat
    7,959
    Thinking lever valves are more reliable and quicker to turn off.
    thereisawizza likes this.
    Aug 2016
    Lancashire
    1,426
    Quote Originally Posted by drip-dry View Post
    The question was about isolating the sections of a heating system if you read it.
    Try not to be condescending and pay more mind to being helpful.
    I have been an Industrial Commercial and Domestic Heating Engineer for 28 years, So I do know not to valve off a boiler as you suggested !
    What has Gas awareness week got to do with Heating system sections ?
    Aug 2016
    Lancashire
    1,426
    Quote Originally Posted by thereisawizza View Post
    They're full bore valves designed for the open vented system circuits we're discussing.
    They have less restriction / frictional resistances to ball valves.
    They're serviceable !
    Roger Welton likes this.
    rpm
    rpm is online now
    Member rpm's Avatar
    7,959
    Lever valves for water & gas can be full bore, take your point about being serviceable though.
  10. The Following User Says Thank You to rpm For This Useful Post:
    May 2010
    Hythe, Kent
    588
    Quote Originally Posted by Last Plumber View Post
    I've come across lever (full-bore) valves and gate valves from the early 90's in the same block of residential flats, guess which ones didn't work......
    I agree gate valves are serviceable but there are two issues. One, if they worked as well as a branded full bore lever they wouldn't need servicing. Two, if you service a gate valve for a customer and it then fails, you end up getting it in the neck from the customer....
    "it was fine till you touched it" etc etc....
    rpm
    rpm is online now
    Member rpm's Avatar
    7,959
    Quote Originally Posted by ChrisKing View Post
    Hi Forum,
    cheers
    Chris
    Don`t know if the usual plastic push fit valves are full bore or not but do know the beggers start leaking whenever I go near them. lol
  13. #12
    Aug 2016
    Lancashire
    1,426
    I agree. The problem a lot of the time is that decent quality 'lever type' ball valves are on the shelf. However, most shelf stocked small gates, 15mm or 22mm are Crud !
    If you buy gates like Crane, the quality is very good. It's all a matter of opinion though.
  1. Radiator valves used as isolation valves on a sink.
    By Skip in forum Bathrooms, Showers and Wetrooms
    Last Post: 16-10-2013, 08:20 PM
  2. Isolation valves
    By duffsparky in forum Plumbing Forum
    Last Post: 10-06-2011, 03:53 PM
  3. Isolation valves on central heating
    By reynard883 in forum Central Heating Forum
    Last Post: 24-02-2010, 11:48 PM
