Results 1 to 4 of 4
Plumbing & Plumbers Forum - Pegler monobloc basin tap problems
Discuss Pegler monobloc basin tap problems at UK Plumbers Forums; Hi I am new to this forum so I hope I'm doing it right. I have recently moved to another house which has three identical Pegler basin mixer taps however ...
    May 2016
    Default Pegler monobloc basin tap problems
    Hi I am new to this forum so I hope I'm doing it right. I have recently moved to another house which has three identical Pegler basin mixer taps however one appears not to be operating as per the other two. I think these taps are quite old and I have tried to provide a photo but so far no luck. Two are right next door to each other but the hot flow is poor from one. Whilst the other works fine, they both are piped up using braided hoses from an isolating ball valves, but the hot side comes from a gravity feed cylinder whereas the cold side on them all comes from the mains. The lever on the one with poor hot flow is slightly stiffer to lift. I can't Identify these valves and hope that I can get some quidance from someone here. Is there a unit inside that needs replacing or could it be furred up and need cleaning? All these taps have a pop up waste lever at the rear. Any advice welcome please. Regards Mogsey
    Attached Thumbnails Attached Thumbnails Pegler monobloc basin tap problems-image.jpg
    jtsplumbing's Avatar
    Tavistock. Devon
    4,807
    Default Re: Pegler monobloc basin tap problems
    Send a photo to Pegler and they will tell you what replacement cartridge you need,
    May 2016
    Thanks for your help sent pict to Pegler they identified tap as one from their LUSSO range. And have a cartridge however I can't prise the satin top from the tap to access the screw underneath any advice please.
    Feb 2015
    Wokingham
    188
    Can you press down and turn it anti clock wise or prise cover off with thin screw driver or blade.
  1. Replacement monobloc basin mixer
    By Richard99 in forum Valves & Taps
    Last Post: 30-08-2014, 07:59 PM
  2. Replies: 22
    Last Post: 21-06-2012, 09:05 PM
  3. Pegler Haze bath and basin tap set
    By WHPES in forum For Sale & Wanted
    Last Post: 30-11-2011, 08:41 PM
  4. Help identifying a monobloc basin tap.
    By Pudding in forum Plumbing Forum
    Last Post: 06-07-2011, 11:02 AM
  5. Basin monobloc mixer tap low pressure on hot
    By delieu in forum Valves & Taps
    Last Post: 15-12-2010, 10:53 PM
