Chatrooms
Replacement Monoblock Tap Lever - what type? -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Valves & Taps
Notices
Old 4 Weeks Ago   #1 (permalink)
z-bed
Info
Default Replacement Monoblock Tap Lever - what type?
I've got hold of an ex-display tap which is missing it's lever, but I can't find a replacement that fits.
Does anyone know what brand of tap uses this type of lever? I looked in B&Q and Homebase but all the levers there screwed into the tap - mine looks like a larger lever fits over the tiny lever and is screwed in place.
Anyone got any suggestions or recognises the brand of tap so I can get in touch with the manufacturer?
z-bed is offline
Old 4 Weeks Ago   #2 (permalink)
WHPES
Info
Default Re: Replacement Monoblock Tap Lever - what type?
If there's no name or mark on it, then it's an unbranded tap you've got no chance as they are shipped in single pieces from China or wherever, and if it breaks you throw it away and start again.
Yor only way is to to go through a few scrapped ones and try and find a lever that fits, but personally I think life's too short form messing with such things, which is why you were given it!
WHPES is offline
Old 4 Weeks Ago   #3 (permalink)
z-bed
Info
I know what you mean Whpes, but the donor seemed pretty sure it came from a high street DIY chain store - most of which only sell half a dozen modern looking monobloc designs. Can't be that hard to source.
z-bed is offline
Old 4 Weeks Ago   #4 (permalink)
WHPES
Info
Maybe, but you cannot get spares other than cartridges.
WHPES is offline
Outside Tap come apart from pipe zee Plumbing Forum 4 30-01-2010 06:07 PM
Intermitant hot (ceramic) tap Elvis Valves & Taps 3 27-01-2010 01:26 AM
Screaming cold tap antioch Valves & Taps 7 13-08-2009 12:50 AM
Best type of outdoor tap badbob Plumbing Forum 3 16-07-2009 08:32 PM
Kitchen Tap Loose WaterTight Plumbing Forum 6 19-06-2009 08:10 AM
