Results 1 to 11 of 11
Plumbing & Plumbers Forum - Tainted water
Tainted water
Discuss Tainted water in the Valves & Taps at Plumbers Forums; I replaced a worktop reusing the existing sink and tap, and the only change in the syatem is the addition of a couple of ballfix valves. Now the water has ...-
20-07-2012 #1New to Plumbing Forum
- Apr 2010
- 10
Tainted water
I replaced a worktop reusing the existing sink and tap, and the only change in the syatem is the addition of a couple of ballfix valves. Now the water has a taint and smells/ tastes faintly of TCP. Not a happy customer.
Any bright ideas?
20-07-2012 #2UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,115
- 306
Re: Tainted water
Tank fed or mains Sprinter? Have known both get a bit discoloured if they've been drained down for any reason! Usually clears up after running for a couple of minutes though
20-07-2012 #3New to Plumbing Forum
- Apr 2010
- 10
Re: Tainted water
On mains. Has a combi boiler. I turned it off at the meter outside.
The bathroom right next to it has no taint and is fine to drink.
I'm suspecting the tap as it was a bit cruddy.
20-07-2012 #4Plumbers Arms member
- 743
- 7
- Thanked 54 Times in 53 Posts
Could be the flux/solder if you used any I guess.
20-07-2012 #5Plumbers Arms member
- 743
- 7
I just found this, maybe it helps. http://www.anglianwater.co.uk/househ...ity/facts/tcp/
20-07-2012 #6New to Plumbing Forum
- Apr 2010
- 10
Re: Tainted water
There's no solder, it's a compression joint. I ran water through the disconnected tap tails into a glass and it was fine, no smell or taste.
So it's the tap. I can only imagine some of the gunk in the spout seal found its way into the body when I moved it. The threaded bit that holds the spout down tight was loose and the body of the tap (still attached to the sink) nearly fell off when I picked it up by the spout. Could some of the grease have been pushed back into the flow?
I dunno, but as it only happend after I had worked on it, it's my fault and I have to put a new tap on to get over it.
20-07-2012 #7Plumbing Forum Contributor
- Mar 2010
- 93
- 5
- Thanked 16 Times in 14 Posts
Re: Tainted water
I think you're being a bit generous. If the original taps are of some age, then your customer has already had good value from them, so why you should you pay the whole cost of replacing them? The customer will end up with something better than they had originally. You might consider pointing out to them that these things happen with old taps when disturbed, but that if they buy (suitable) taps, you'll fit them for 1/2 rate / nothing.
20-07-2012 #8Steady Plumbing Forum Contributor
- Apr 2012
- Edinburgh
- 204
- 5
- Thanked 17 Times in 17 Posts
Re: Tainted water
There seems to be a common theme running over several posts in a few of the forums over the past few days. Namely the customers all coming out with the old "It wasn't like that before you touched it" excuse. Do you think it might be open season on plumbers just now, a bit like the Glorious Twelth for shooting birds.
09-08-2012 #9New to Plumbing Forum
- Apr 2010
- 10
Re: Tainted water
They have been away for a few days and the taint is back. There is a new tap fitted and the taint appears to stop if the water is run for a while but returns when the tap is turned on again.
So there is no solder involved, and it's mains fed. What could be interfering?
09-08-2012 #10Top Plumbing Forum Contributor
- Apr 2011
- 799
- Thanked 73 Times in 72 Posts
Re: Tainted water
Report it to local water authority,it could be a mains problem
25-08-2012 #11
Help - Bath/shower triple valve issue - cold water eliminating hot water.
By olfrog in forum Plumbing ForumReplies: 5Last Post: 16-10-2011, 07:20 PM -
Water Softener: hot water soft; cold water hard?
By Nikster in forum Plumbing ForumReplies: 29Last Post: 29-06-2011, 09:45 PM -
Ariston water heater-erratic water pressure and water running down side of house?
By cairns in forum Plumbing ForumReplies: 0Last Post: 26-09-2010, 08:21 PM -
Not hot water, not water from hot water tap, boiler not firing
By TobyW in forum Plumbing ForumReplies: 3Last Post: 29-06-2010, 02:47 AM -
Water flowing into cold water tank from hot water cylinder
By rustyands in forum Plumbing ForumReplies: 3Last Post: 11-09-2009, 11:08 PM
1Likes
Relief valve for Unvented Indirect...
41 Minutes Ago in Plumbing Forum
