Plumbing & Plumbers Forum - Hot tap no water
Like Tree3Likes
  • 1 Post By galaxy_plumbing
  • 2 Post By Mickyplumb
Hot tap no water
Discuss Hot tap no water at UK Plumbers Forums; my hot tap in the bathroom will turn but no water will come out all other taps both h&c all work fine any ideas please ?...
    Oct 2009
    wrexham
    18
    Default Hot tap no water
    galaxy_plumbing's Avatar
    Jan 2012
    St Albans
    1,256
    Default Re: Hot tap no water
    seized tap maybe..shut the water, remove valve body and check if is working as it should. It could be a blockage too but i think you would get at least some drip from it.
    spanner likes this.
    Plumber and heating engineer in St Albans - http://www.galaxyplumbing.co.uk. Call Martin on 07802 645743 for plumbing and heating in Hertfordshire. Don't understand my English? Please ask me in Slovak then
  3. The Following User Says Thank You to galaxy_plumbing For This Useful Post:
    May 2012
    301
    Quote Originally Posted by karlhayes View Post
    If it's a BS5412 valve, i.e not rising spindle then once you remove the head, check to see if you have the circlip still stuck on the spindle.
    jtsplumbing and Best like this.
    N.Ireland, United Kingdom
    7,009
    On the old design taps that are basically a screw that moves a washer up & down, then washer could be stuck, - renew it.
    If it is more modern design then it could still be washer, but also could be works disconnected. As said, check circlip, but could be the common problem of wear on the O rings inside the works, that means water enters into the part the threaded bit goes. This is often on hot taps due to heat. Remove the works, take clip off, ( the works are in 3 parts), tap spindle out, screw spindle apart, & as you probably won't be able to match the O rings exactly, just clean & grease with Vaseline or silicone grease, & put together & refit. May last reasonably well. If you could get a new spindle with same splines to suit tap head, then often better a new one.
    spanner's Avatar
    Aug 2010
    Archway, London UK
    1,112
    Quote Originally Posted by galaxy_plumbing View Post
    If the taps are just ordinary standard BS1010 turning on/off taps, you'll probably find the spindle (which has a left hand thread) has probably come loose in the tap body and stuck down..Just as galaxy has said and dont forget to replace the rubber washer.. Good Luck PaL
    Safety Message
    CARBON MONOXIDE CAN BE FATAL THIS IS A RESULT OF POORLY MAINTAINED APPLIANCES DO NOT LEAVE IT TO CHANCE GET YOUR APPLIANCE SERVICED TODAY!!!
    If it aint broke don't try to fixit
  1. Water flowing into cold water tank from hot water cylinder
    By rustyands in forum Plumbing Forum
    Last Post: 11-04-2015, 07:43 AM
  2. Hot water timer setting advice Ideal Icos, hot water tank
    By nbdoris in forum Central Heating Forum
    Last Post: 09-02-2013, 10:13 AM
  3. Replies: 3
    Last Post: 07-01-2013, 12:09 AM
  4. Replies: 5
    Last Post: 16-10-2011, 07:20 PM
  5. Replies: 2
    Last Post: 10-08-2011, 05:50 PM
  6. Water Softener: hot water soft; cold water hard?
    By Nikster in forum Plumbing Forum
    Last Post: 29-06-2011, 09:45 PM
  7. Replies: 2
    Last Post: 03-10-2010, 05:50 PM
  8. Replies: 0
    Last Post: 26-09-2010, 08:21 PM
  9. Replies: 3
    Last Post: 29-06-2010, 02:47 AM
  10. Erratic pressure
    Last Post: 25-09-2007, 10:19 PM
tap turns but no water
tap turns on but no water
hot tap turns but no water
tap keeps turning no water
how to fix a tap no water
