Results 1 to 11 of 11
Plumbing & Plumbers Forum - Unable to fit DIY pipes bought from Canada
Discuss Unable to fit DIY pipes bought from Canada in the Valves & Taps at Plumbers Forums; Hi Guys, I bought a bidet from Canada which can be fitted over the toilet stool. The problems is that the pipes that cAme with it, I found out later, ...
    Jun 2012
    Default Unable to fit DIY pipes bought from Canada
    Hi Guys,
    I bought a bidet from Canada which can be fitted over the toilet stool. The problems is that the pipes that cAme with it, I found out later, are in north american measures.
    The main problom is fitting the "Adapter" shown in the attached diagram and picture:-
    between the 22 mm pipes under the washing basin.
    Cold Water under basin 22 mm pipes.jpgPicture of British underbasin cold water pipe with a ruler.jpg
    I would greatly appreciate help with this regards.
    Best wishes
    Matthew
    diamondgas's Avatar
    Newcastle Upon tyne
    6,050
    Default Re: Unable to fit DIY pipes bought from Canada
    Hi mathew,
    Where in the country are you? Ther'll most likely be a merchants in your area who can help get the adaptors you need! Up here in Newcastle I'd be consulting a firm called Crosslings, Not sure if they're national or not?
  3. "Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity." Albert Einstein
    Jun 2012
    Thanks diamondagas,
    I'm in Kent, Whitstable. I have been to few merchants in an industrial park and they were unable to help me.
    diamondgas's Avatar
    Newcastle Upon tyne
    6,050
    Quote Originally Posted by masaw View Post
    Thanks diamondagas,
    Maybe someone down your way will give you some advice mate I supose you've checked out the manufacturers website for suppliers in UK? Gave them a call? Just a couple of obvious roads no doubt you've been down?
    Nov 2009
    134
    try someone like pirtek.
    mountainman's Avatar
    Jan 2012
    Essex
    3,201
    Default
    Quote Originally Posted by archiedale View Post
    That sounds like a good idea or there is a company in Barking, Essex. called Abbey Hose that may be able to help you.
    Dec 2011
    134
    fitting this would contravene water reg and are illegal
    Jan 2012
    Essex
    3,201
    Default
    Quote Originally Posted by aqualogic7 View Post
    Could always fit a couple of double check valves tho.
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    Quote Originally Posted by mountainman View Post
    How irresponsible of you.
    That is a total unacceptable way of making an item "legal"
    This is not the way to make it legit. And should never be done
    "nothing is impossible"
    Tavistock. Devon
    1,794
    Why would you want this thing from Canada ? What do you mean it fits over stool ? do you mean it some how clips around wc bowl, This sounds totely illegal and you could leave yourself open to prosecution by local water board.
    Dec 2011
    134
    must have lots of money as fine would be £1000 per contravention of water regs
  1. Unable To Post In Main Forums
    By sollyhouse in forum Links, Forum Updates, News and Site Suggestions
    Last Post: 01-11-2011, 09:01 PM
  2. Canada
    By KingDoey in forum Plumbing Forum
    Last Post: 05-01-2011, 05:18 PM
  3. Plumbing in Canada
    By helpsy in forum Plumbing Forum
    Last Post: 03-12-2009, 12:57 AM
diy plumbing canada
