Results 1 to 9 of 9
Plumbing & Plumbers Forum - New drain valve
New drain valve
Discuss New drain valve in the Valves & Taps at Plumbers Forums; No more stuck washers http://www.hvpmag.co.uk/MemberPages/...e.aspx?id=1314...
    mikegas's Avatar
    Feb 2010
    1,214
    Default New drain valve
  2. GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply.
  3. #2
    mutley racers's Avatar
    Jun 2009
    Hampton court, Surrey
    1,746
    Default Re: New drain valve
    thats just like sticking a service valve on the end. I thought they were classed as un-capped pipework
    steveb's Avatar
    Nov 2007
    hythe hampshire
    9,099
    that's not a bad idea. can't be a rubber seal around the ball though otherwise it would melt when soldered. maybe teflon or something else heat proof.
    Whn1's Avatar
    Mar 2012
    London
    1,295
    Do they make left and right sided ones?
    GSR engineer based in south east London
    Plumbers Arms member scotty plumber's Avatar
    Jan 2012
    581
    Nice idea!
    N.Ireland, United Kingdom
    2,023
    Sensible! Assume it has seals like on a lever valve.
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,567
    what happens when it passes or leaks through the centre,its not a good idea imo
    GASMAN
    IMPOR
    2,023
    Quote Originally Posted by gas man View Post
    That's what I meant by lever valve teflon seals, - if it hasn't them & just has rubber seals, then it will leak at screw. Hopefully it will have same seals as some of the heavier full bore service valves.
    RPG 80's Avatar
    Jan 2012
    South coast
    188
    i like the B&Q jobbies you can only operate by opening with a screw driver situated inside the spout
  1. Drain valve problem
    By doitmyself in forum Central Heating Forum
    Last Post: 08-04-2012, 07:55 AM
  2. Spa Drain Valve
    By Veggie Dave in forum Plumbing Forum
    Last Post: 24-01-2012, 04:04 PM
  3. Replies: 22
    Last Post: 10-07-2011, 09:42 AM
  4. Draining down without a drain valve
    By dan_the_plumber in forum Plumbing Forum
    Last Post: 08-05-2011, 04:15 PM
  5. no drain off valve....
    By that bloke. in forum Plumbing Forum
    Last Post: 17-11-2010, 07:30 AM
central heating drain valve stuck
veggie dave
powered by vBulletin drain check valvedrain valve newwhat is inside a central heating drain valvehow to release a sticking central heating drain valvenew drain valves
