Checkout the UKPF Chatrooms - Click Here
(Please ask any plumbing questions in the main forums, these chatrooms are for general banter)
Purchasing Taps - Low or High Pressure? -
Go Back   Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK > Plumbing Forums > Valves & Taps
Notices
Old 29-03-2009   #1 (permalink)
UnderPressure
Info
Default Purchasing Taps - Low or High Pressure?
HAm seeking some advice with purchasing new taps. I am told that due to the age of my property and design of my gravity fed water system, it is imperative that I purchase low pressure taps for my new bathroom/ensuite etc.
What constitutes a low pressure versus high pressure tap? What is considered to be low pressure? What is considered to be high pressure?
Can anyone make any recommendations at to manufacturers of good quality "low pressure" mixer taps for handbasins?
Thanks very much
UnderPressure is offline
Old 29-03-2009   #2 (permalink)
Mike Jackson
Info
Default Re: Purchasing Taps - Low or High Pressure?
Ask in the merchants where you are buying. Their catalogues will give pressure ratings for taps. if you want good quality you'll have to pay for it. Buy a cheap tap and it will not last long. Go for an established manufacturer rather than cheap foreign imports from the sheds.
Mike
Mike Jackson is offline
Old 30-03-2009   #3 (permalink)
UnderPressure
Info
Mike
Can you recommend an established manufacturer of good quality - low pressure mixer taps?
What are "the sheds?". I need to know in order to be sure I avoid them
Regards
Paul
Old 30-03-2009   #4 (permalink)
Mike Jackson
Info
Taps= Armitage Shanks, Bristan, Pegler.
Sheds are the DIY sheds B&Q, Wickes etc.
Mike
Old 30-03-2009   #5 (permalink)
Bernie2
Info
Careful buying taps. In the sheds at one time you could buy taps that where not to standard. There was no law to prevent a company selling such taps. But there was if you fitted them. Check the WRc site, they have great big lists of acceptable stuff.
We had loads of problems at one time with people going to the likes of B and Q fitting there own taps and after a short while they would leak like mad from the packing gland. Breaking them down showed nothing wrong, they just could not stand the pressure in the UK. More so now with combis supplying the hot at mains pressures.
Best get a good make like those mentioned or those on the WRc list and shop around for best prices. Shanks and Armitage are really good but can be pricey.
And don't forget your ball o flows and nrv's if required.
Bernie2 is offline
Old 01-04-2009   #6 (permalink)
UnderPressure
Info
Thanks fellas for the advice. Will look for the brands you recommend
Bernie: I found the WRc site but found no lists. Do you have the URL to point me in the right place? Thanks
Old 29-06-2009   #7 (permalink)
kwakerdude911
Info
taps are taps - hi or low pressure dont really matter - the old kitchen tap in yer kitchen will normally be under mains pressure - does it blow up ??
if u want to gothe way usa is going get disc taps or if u are on about showertaps get a power shower fitted - job done
kwakerdude911 is offline
Old 30-06-2009   #8 (permalink)
Vado-uk
Info
Send a message via MSN to Vado-uk Send a message via Skype™ to Vado-uk
Thanks very much
Low pressure is generally around 0.2bar and high pressure is generally a minimum of 1.0-1.5bar.
Some manufacturers only offer high pressure taps as this is what is used on the continent. In the uk, like yourself a lot of people have gravity fed systems which is why you need low pressure.
thanks
Vado-uk is offline
Old 30-06-2009   #9 (permalink)
Dave
Administrator
Dave's Avatar
Info
thanks
Aaron..appreciate your input but do not link to website until things are sorted....
thanks dave..
__________________
Dave is offline
Old 10-07-2009   #10 (permalink)
Bernie2
Info
Hi! Underpressure.
I am very sorry I gave you the wrong name. Its WRAS, Water Regulations Advisory Scheme It stands for Water Regulations Advisory Scheme. Its worth a look, what you want seems to be on there.
Bernie2 is offline
gravity HW & mains CW mixer tap problem MarkB Valves & Taps 7 23-03-2009 12:51 PM
Hot water pressure low bladerunner Plumbing Forum 9 22-03-2009 05:56 PM
Low pressure taps and noise tipper Valves & Taps 5 02-12-2008 07:56 PM
no pressure to taps in en-suite Vinny Plumbing Forum 7 24-11-2008 09:41 PM
High pressure for couple seconds.. zxac Plumbing Forum 5 16-10-2008 05:20 PM
