Plumbing & Plumbers Forum - Electric underfloor heating
Like Tree3Likes
  • 2 Post By Chalked
  • 1 Post By Chalked
Discuss Electric underfloor heating at UK Plumbers Forums; Hi folks, an underfloor heating question..... I have a bare concrete floor in the hall way. Can I simply lay flat electric cable heating on this then put floor tiles ...
    Banned
    Jul 2016
    187
    Default Electric underfloor heating
    I have a bare concrete floor in the hall way. Can I simply lay flat electric cable heating on this then put floor tiles on top? I`ve been inspired seeing some ornate tiling inside a front door, but want to put cable heating underneath this. Will I lose a lot of heat into the screed? Is there an approved way to do this?
    Thanks for any advice!
    9,660
    Default Re: Electric underfloor heating
    Loose a lot of it into the uninsulated screed
    Chalked's Avatar
    3,810
    Use 10mm insulation boards, fas end down with powder tile adhesive. Prime the boards, then tile. This gives a food substrate to tile onto and insulates the ufh from heating the sub floor.
    Uheat – Wojtek and colshaws like this.
    Banned
    Jul 2016
    187
    Thankyou gentlemen! Very helpful. Its just the floor is obviously all laid, its the original concrete and I cant start digging it up so I`m just considering my options. I suspected I`d lose a lot into the screed.
    Chalked's Avatar
    3,810
    Did you read my post??
    This all goes on top of your existing floor
    Riley likes this.
    Banned
    Jul 2016
    187
    yes ty Chalked I did. Yes I understand. I didnt want to be raising the floor level (with insulation boards) because I dont want steps between the hallway, kitchen, living room. I wanted a level floor across the downstairs, to allow a smooth, neat transition between rooms.
    Thanks again.
    ** UKPF Sponsor **
    Jul 2016
    71
    Hello everyone,
    Steve, we do 6mm XPS polystyrene boards which can be installed by using 1-2 mm flexible tile adhesive. Heating mat goes on top.
    I totally understand you don't want to have a little step but if you use the insulation boards we know the UFH will work and will be more efficient and cheaper to run.
    It's a much better soltuon rather than using higher wattage of heating mats or cables on top of concrete.
    If you can't go for insulation boards you can use a Thermal Primer and 200W/m2 mats but it will cost you more to run.
    I've got 6mm insulation board on top of uninsulated concrete with 200W/m2 mat on it and it works perfectly and doesn't cost a lot to run.
    Hope that helps.
  8. The Following User Says Thank You to Uheat – Wojtek For This Useful Post:
  1. Electric underfloor heating
    By Matchless.plumb in forum Central Heating Forum
    Last Post: 06-09-2015, 09:06 PM
  2. Wet underfloor heating from electric heater advice.
    By ee0jmt in forum Central Heating Forum
    Last Post: 30-10-2014, 07:30 AM
  3. Wattage help for electric towel rail in ensuite with electric underfloor heating
    By DistantHillsBB in forum Bathrooms, Showers and Wetrooms
    Last Post: 23-02-2014, 10:02 PM
  4. electric or hot water underfloor heating advice needed please
    By butlerps in forum Central Heating Forum
    Last Post: 01-11-2012, 07:44 PM
  5. Electric Underfloor heating opinions
    By ddm in forum Plumbing Forum
    Last Post: 29-07-2012, 01:07 AM
